Can I use Lucas 80/90 instead of 75W-90 in diffs?
There are quite a few Ford dealers that use 80W90 gear oil in the rear diffs because of bearing problems. I don't know that it's ever been proven whether the oil caused the problems or if something else changed, like a different manufacturer or something, but it seemed that when Ford went to the 75W140 a lot of bearing problems showed up.
If warranty is buying the oil I use the Ford 75W140, if the customer is paying I usually use 80W90 Pennzoil because our parts department keeps that in stock for people not wanting to spend the big money on Ford oil.
I wonder did bearing problems start appearing because with the 75w140 no-one ever changes it?
Ford says if it never gets moisture in it that it is basically good for life.
I have 180,000 KM's on my truck and consistently carry 900lb's in the box so I wonder if I should switch to 80w90? Any suggestions? I changed my 75w140 about 3 months ago.
VaFordman26
07-02-2017 07:48 AM
IcemanV8
06-18-2008 10:13 PM
