1999 Hub/Bearings vs. 1999.5 Hub/Bearing
I have a pre March 1999 SD F-250 4x4 with a loose LF bearing. Can I put the newer hubs from 1999.5 on my truck? I would like to get the rotors that are less prone to warping. Just need to know if the newer hub will bolt up. Or if there is a good place to get a SD style Dana 60 I would do, since i think Eaton has an Elocker that fits the Dana 60??
When my bearings went bad on my 8/98 build date truck I switched to the newer designed hubs and rotors. Only place you can buy the pre march 99 hub assemblies is threw the Ford dealer and they want so much $ for them you can get the newer aftermarket hubs and rotors for the same price as just the old hubs. The only difference between the old design and the new is the plate that the lugs are pressed into on the hub assemblies. As I recall the old design has a 10 mm thick plate and the new ones are 13mm thick. When they did that it moved the rotors out 3mm so they had to design new rotors and make the hat of the rotors 3mm deeper to move it back.
Replacement bearings for front hubs pre '99 f250 sd
Let me tell ya what happened to me. I have a early '99 model F250 SD. I was on the way to N. Carolina and about 30 minutes from my destination the left front bearing started screaming! After going to the ford dealer and falling down with sticker shock over the price of a hub assembly, I decided to knock the bearings out and see if I could find a replacement.(something the dealer said was impossible).I actually found bearings at Advance Auto parts. I know, I couldn't beleive it either. Anyway, replaced both sides for less than $15.
I have an early 99 F250, and I have a slight rumble in the driver's side front. Not bad enough that I am worried yet, but wondering if that is the bearing starting to go bad?
Picard: I (and others) would be very interested if you would post some more details or step-by-step on your bearing replacement.
Dick
salewit
13
04-12-2005 02:25 PM
tj21
03-09-2005 02:30 PM
