Air Compressor recommendations
#31
Originally Posted by Torque1st
Do not buy the maintenance free oil less type compressors. They are not only
horrendously noisy they wear out VERY quickly. They are usually made of aluminum
with the motor directly coupled to the compressor and are usually good for just
a few hundred hours of operation (if you are lucky).
I have it installed in the pump room outside my garage and it still is loud enough to disturb any conversation going on in the garage.
BUT- I have had my compressor for 8 years (it was my wife's first x-mas gift to me!!) and with little to no maintenance (I know, I know!). it runs all my tools with no problem. but it is hooked inline to a 80 gallon air tank with a bad motor for reserve air supply,too!
packrat
#32
Originally Posted by Crash687
take a good look at how the two are built, you will clearly see the castings are heavier on the IR. IR compressors are 100% duty cycle rated[does not need to shut off], CH is not.
Not saying that CH is junk, will probably work fine if this is just a home use (light duty)compressor. Now if you plan on restoring cars/trucks for a living out of your home, by all means buy an industral air compressor(Gardner Denver, Sullair, IR, Quincy)this is something you are going to run 5 days a week.
To have a good supply of air for just about whatever you want to run, an air compressor sould put out at least 13 to 16 cfm @ 90 psi. 90 psi is where most air tools are rated for air consumption and rated output.
#33
Originally Posted by ford390gashog
all ch oil lube belt drive compressors are 100% duty cycle the porter cables are only 50% duty cycle but i have run mine past that point many times
running a compressor past its duty cycle shortens the pumps life, like pulling too much weight behind a truck.
#34
Well I ordered my compressor today..After about 6 hours of online work I got what I think is the best for the money..5hp 20 cfm at 100 psi 19 cfm at 175..20,000 hour rated life...Supposed to be super industrial...Its called Devair made in canada..If my current setup will drive it ok amperage wise I may consider getting a 7.5 hp motor off ebay and a diff pulley and go with that at a later time.
http://www.air-compressorsvacuum-pumps.com/simplex.htm
Dick
Dick
#37
#39
A Sullair will give you better performance than any IR. We have a Sullair at work for the main air system and several old CH's that the maintenance guy ripped the pump and motor from and piped the Sullair into the CH tanks and placed these in various places throughout the plant, so high use areas will have a reserve of air.
#40
There is an immense difference between the industrial duty air compressors and the hardware variety. I/R makes both kinds and you just cannot compare the two types. I have spent a lifetime working on compressed air equipment and can tell you that I/R, Sullair, G/D, Quincy, LeRoi are all excellant machines. The only real difference between them is the quality of their controls. If they weren't good they wouldn't be so popular. You do get what you pay for.
#41
Originally Posted by SirHailstone
IR is NOT 100% duty cycle rated and experiences more long term problems because of it's design to shutoff and restart instead of keeping the pump running and blowing off un-needed air.
All the big industral air compressor manufactures compressors are all in the ball park. They have to be it is a very competitive buiness. Comes down to features, packaging and price.
#43
LARIAT 85
31
09-26-2017 06:12 PM
speakerfritz
6.4L Power Stroke Diesel
11-26-2016 04:24 PM
BGF100
08-01-2016 04:00 AM
