93 f150 4x4 dash switch - Ford Truck Enthusiasts Forums
Old 12-04-2004, 08:13 PM
plowwman plowwman is offline
plowwman is starting off with a positive reputation.
Question 93 f150 4x4 dash switch
i have a 1993 f150 4x4 that will not engage the 4x4 with the dash switch. i have been told this is a common problem with this truck. i have the switch out of the truck(part#f2tb-7z155-aa) .could somebody please tell me how to check this switch with a meter before i order a new one (dealer price $212.00) any help would be greatly appreciated thanks plowwman
Old 12-05-2004, 02:20 PM
thomasr thomasr is offline
thomasr is starting off with a positive reputation.
I also have a 93 F-150 4X4, and I occasionaly have/had problems engaging 4 wheel drive. I too, initially thought it was my push-button gone bad, but after talking with some knowledgable folks about it they gave me a couple other things to look at. Seems the connector going to the solenoid that actuates everything (sorry, don't know the exact nomenclature of all these parts) is prone to coming loose, getting dirty, getting wet and basically not making good contact. I took it apart as best I could, used contact cleaner and some dental instruments and cleaned the connector up, put it all back together, used a couple crossed zip ties to hold everything tight and sealed the edges with some RTV. That worked great for awhile, then it happened again, but this time I could hear clicking as I pushed the button, but it never would engage. Had the wife push the button while I listened from underneath (pretty risky considering the amount of life insurance I have on myself) and determined that clicking noise was coming from the solenoid itself. Took it apart and what a dirty mess inside. Cleaned it up real good, put it all back together and everything worked great. Now you may have already exlcuded all this in your troubleshooting...just thought I'd throw it out there for something else to ponder. Good luck!
RWT
Old 12-05-2004, 02:36 PM
sphinx's Avatar
sphinx sphinx is offline
sphinx is starting off with a positive reputation.
I've had various problems with the one I had too. Never saw the switch go bad but I did have to replace the Control module (the box that makes the clicking noise in the cab when you push the 4x4 button) and I had the servo motor on the tranfer case itself go bad. I would check those before spending anything.
Old 12-05-2004, 05:17 PM
RWT
4x4 switch Vinford 1999 to 2016 Super Duty 10 05-30-2015 04:29 PM
No Power To 4x4 Switch Smokey1961 1997 - 2003 F150 15 06-01-2014 11:06 AM
F250 Instrument Cluster Dash Radio Trim Bezel FORDSDOWNER 1999 - 2003 7.3L Power Stroke Diesel 12 06-09-2013 07:34 PM
need help installing transfer case switch navigatorstang 1987 - 1996 F150 & Larger F-Series Trucks 13 01-12-2011 12:12 PM
1998 F150 4x4 will not engage goodtobeeme 1997 - 2003 F150 4 12-28-2010 05:44 PM
Tags
150, 1996, 4x4, 93, 96, button, cylinoid, dash, f150, f2tb7z155aa, ford, motor, part, push, switch, wheeldrive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
