thoughts on tilt front end
guys, im gonna start sunday on trying to figure out how to flip my front end. for the guys that have done it what can you tell me about bracing the sheet metal and anything. what am i getting myself into? by the way its a '49 f-1.
thanks for all the help thus far too.
There are several considerations to flipping a steel front end. First you must bolt the hood to the fenders in such a way as to preserve the gap so that it fits correctly. Second, you'll need a substantial hinge and way to attach it to the front end that will support the weight of the fenders in both the open and closed position since you'll no longer have the cowl attachment and support rods to keep everything in alignment and prevent sagging. Third You'll need to cut the inner fenders to clear the cowl and the outer fenders to leave the rear sections attached to the cowl, so there's no turning back without replacing or repairing the cut parts. It's possible to leave the outer fenders one piece, but then it will require two people to guide the ends of the fenders to keep from scraping the cowl. You'll also need to fabricate some sort of guide and/or latch system to keep the 2 halves of the fenders aligned or to keep the one piece fenders from moving and scraping the cowl while your driving. The biggest consideration tho is the weight of all that heavy metal. Are you going to be able to physically lift it up to the tilt position, and how stable is it going to be once it's up there, and what about letting it down again? Most tilt front ends are done with fiberglass replicas, not with steel parts. The PO I bought my panel from had the flip front end done by the owner before him undone and the hood rehinged with stock hinges because he found the steel flip front too unweildy to deal with safely. Fortunately for me they hadn't cut the pristine front fenders, unfortunately they had cut the inner fenders. The chrome front hinges are still in place at the present moment.
John Niolon has a good bunch of info on this:
http://www.clubfte.com/users/jniolon...gfulltilt.html
I bookmarked it a while back.
Norb
Norb
Actually the front end is not that heavy. I have a 1950 Ford F1 that I got with the front end already unbolted. It still has the entire grill there and the headlights. Steve and I lifted it off today boy it made the backing plates and hubs easy to remove and it was not bad at all. I bet it does not weigh 100 lbs maybe 75? What do you thing Steve? I think it would be interesting. I would have to put together a good system so I could slide the front end out then tilt it forward. Maybe put a slot in the frame for a few pieces of flat steel to slide in that are attached the front end. Get a piece of strap steel bent to the shape of the slot for a wider sliding area. Put Teflon around the bolt to allow it to slide easy. Maybe use a bushing that would roll on the bolt in the slot. The weld a couple of pieces of angle iron to the inside channel of the frame for the steel to slide in also. Kind of like how an old drawer slide. Then line the angle iron with teflon for easy sliding also. I think it would be a very sturdy and reliable sliding system.
Some one at the super nationals last spring had built a tilt front end on an F-1
that slid forward to clear the cowl using some heavy duty drawer glides. I've been toying with a flip hood using garage door rollers and track as guides and that probably could be adapted to a tilt front end. Don
I've often thought of using a large version of one of those glass door latches that you click, and then they "pop" out to support the ends of the fenders. You could use a solenoid, like one of those door popper maybe? With a skid on it so it supports the in-tact fender as it passes the cowl maybe?
Also, what about a bumper that is filled with lead to counter balance the weight of a steel front end? Or springs to pull it over center?
Just goofy ideas... I've never built one, but I have thought about ways to improve one on a friends' '53.
Sam.
Sam.
Sam I beleave the guys at the s/nats uses some sort of screw drive arrangement on a motor mounted in a short piece of fender which remained attached to cowl. That would also act as a positve lock withthe hood down.
I see the drawin board coming back out.
axracer, Lets just say that I were to loose my mind and decide to do a steel front hood filp, I'd be forced to take the fenders to a metal fab shop and have then roll a piece to add along the cut on both sides,as support it and to add strength.
i personally tried to use the original metal body pieces and it was just to heavy to work with so i bought the fiberglass front end from us body for my 78 f250. its came alittle more ruff straight from the mold than i would have liked but o well. the hinges they send with it are junk so i made my own the work great from an old set of spring hangers and a set of drop shackels i got from a lowering kit straight from pep boys
As a teenager in the 60's I owned a 53 Henry J with a tilt front that I drove on the street and occasionally at the strip. I guess I have been heavily influenced by the gassers of the 60's and I really enjoyed the tilt front when it came to working on the engine.
My 55 F100 has a fairlane one piece front end. Hopefully when I'm finished it will open and close without scraping off paint and remain aligned. I've tried to build some adjustability into it so that misalignments can be take care of. I like axracer's ideas on alignment methods when it closes. Still haven't decided how I will open and close it. I've looked at electric actuators, I already have a convertible top hydraulic system, or I may just go with good old manual opening.
I didn't want any kind of support rods for the rad support, so I welded up a cradle for the radiator to sit in. I fabricated a stainless surround that bolts to the cradle and holds the radiator in position. I used rubber cushions inside the surround to isolate the radiator from direct contact with any metal.
I've still got a lot of details to work out, but it all seems minor, considering that I've changed so many things on my truck that there's not much left that's original. Moving farther to the Darkside you know.
