4x4 Vibration
4x4 Vibration
1999 F250 crewcab lariat 4x4 diesel 175000 miles
I have a vibration in the front end when in 4x4, most noticible when decelarating from 40 mph to 20 mph in 4x4.
Thought it was the u-joints.. replaced all three u joints on front driveline... was not the u-joints, or did not fix the problem.. although one was bad.
Put the truck on a lift and found out that my lower left ball joint was shot.. so i pulled the axles and pressed in all new ball joints, top and bottom both sides..had to replace both inner and outer axle seals both sides..repacked the front hubs the best i could ,with the non servicable front hubs. tightened things up but still have the nasty vibration.
Now I am thinking I have a unbalanced driveline.. but i am in a remote part of Alaska with no shop to balance the driveline.. Wonder if any one has tried to re-phase the driveline by twisting it 45-180 degrees or balance with hose clamps any techniques other than trial and error??? ideas...
Late.............
Late.............
Originally Posted by cobiyero
The u-joints on the axle appeared to be in great condition.. nice and tight.
When you had the wheels apart were you able to swivel them around freely?
Kwikordead.. thanks for the input... This has me stumped..
when i had the wheels apart and the axles out the u joints swiveled around free but not sloppy.... The front most u-joint on the driveline was bad... missing all the needle bearings in one cup... thought i found the problem...but nota.. so i repaced the other two u-joints on the front driveline.... to no avail....
then the rest of the front end deal....
so the latest road test..
4x4 with hubs locked........significant vibration 28-49 mph
hubs locked, 4x4 disengaged.........much milder vibration at the same speeds
4x4 engaged, hub disengaged.... no vibration at all
all going straight down the highway
This makes me question my driveline balance theory??
I don't know
I don't know
I don't know
I don't know
IDIDieselJohn
12-01-2014 04:26 PM
l67cooled
12-29-2009 04:53 PM
GREENS AUTO AND MARI
1999 to 2016 Super Duty
04-07-2009 04:24 PM
Markadeck
04-23-2008 07:29 PM
