Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-03-2004, 06:00 PM
Curious97Ranger Curious97Ranger is offline
Garage is empty, add now
Curious97Ranger is starting off with a positive reputation.
'97 Ranger gas guage problems
The guage is not registering at all. It will budge/move a little bit when I turn the key, but once running the needle drops to the bottom. Is it possibly the guage itself and not the sending unit? How do I test the guage? If it IS the sending unit....what a mess....the sending unit and the fuel pump are all on one part (thanks Ford) and not exactly cheap.
Any help would be greatly appreciated.
  #2 (permalink)
Old 12-04-2004, 12:11 AM
sixpack2639's Avatar
sixpack2639 sixpack2639 is offline
sixpack2639 is starting off with a positive reputation.
Reach up on top of your gas tank and unplug the cannon plug from your sending unit. Turn on key. If guage goes to full sending unit is bad or float is full of gas. I had the same problem with my 96 Ranger and found the float(brass barrel type) was full of gas due to a hole worn in it from the arm it was attached to. I opted to just replace the unit since the truck had 86k miles on it and didn't want to have to have to drop the tank again any time soon. Easiest way to replace the sending unit is to pull the bed bolts and slide the bed back but on mine that wasn't an option as I have a fiberglass toneau and a Ford bed liner in it. In my case it was easier to drop the tank and that was a bear to do without help. Getting it out wasn't so bad...it was getting it back in that sucked. Hope that helps, Carl
__________________
Carl
My Fords:
96 Ranger Splash 2.3l R1
95 F-150 Scab 4.9l R2
65 Mustang Hardtop 200ci I6 3 Speed
65 Mustang Hardtop 200ci I6 Automatic
Tags
97, problems, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
