frozen engine - Ford Truck Enthusiasts Forums
General Automotive Discussion
frozen engine
Old 12-03-2004, 05:11 PM
nick65f100 nick65f100 is offline
nick65f100 is starting off with a positive reputation.
frozen engine
I have 65 ford that I purchased about four years ago, this truck ran fairly well when it was purchased. However after sitting for a couple of years the engine is frozen. I have tried removing the plugs, pouring oil in the cylinders and prying the fly-wheel back and forth.
If anyone has any other suggestions they would be appreciated.
Thanks.
Old 12-03-2004, 05:20 PM
cobraguy cobraguy is offline
cobraguy is starting off with a positive reputation.
If the truck has a manual tranny put it in high gear and try rocking it back and forth
Old 12-03-2004, 09:45 PM
will do that, thanks for the feedbak
Old 12-04-2004, 12:34 AM
GregTruck GregTruck is offline
GregTruck is starting off with a positive reputation.
First "oil" will not do the job if it is motor oil. You need to use a penetrant like PB Blaster and/or Marvel Mystery Oil. Let it soak for a few days. You should be able to get a socket and breaker bar on the crank bolt. 3/4 drive tools would be ideal but you may get away with 1/2 drive. Use a long section of pipe in conjunction with the breaker bar for a lot of extra leverage.
I keep an 18" pipe in my toolbox and use it all the time. Works great on all these old rusty bolts we deal with.
Old 12-04-2004, 01:12 AM
Fredericks F750 Fredericks F750 is offline
Fredericks F750 is starting off with a positive reputation.
Marvel Mystery oil
I purchased a a 1963 Mercury Meteor last year that had sat since 1973.It was froze up and would not budge so I removed the sparkplugs and dumped in some Marvel oil into each cylinder and then reinstalled all the sparkplugs (to prevent dirt or rust from falling in)except one where I threaded in an adapter and hooked up an airline from my air compresser and pumped the cylinder full of air and the engine finally cranked.If it worked for me it may work for you.Good luck.
Old 12-04-2004, 01:59 AM
FORD352V8 FORD352V8 is offline
FORD352V8 is starting off with a positive reputation.
Soak the cylinders with some penetarting oil (brand doseant matter all the same), and keep soaking those cylinders rocking the crank back and forth til she breaks free.
Old 12-04-2004, 09:08 AM
Flip4ford's Avatar
Flip4ford Flip4ford is offline
Flip4ford has much to be proud ofFlip4ford has much to be proud ofFlip4ford has much to be proud ofFlip4ford has much to be proud ofFlip4ford has much to be proud ofFlip4ford has much to be proud ofFlip4ford has much to be proud ofFlip4ford has much to be proud of
Soaking the cylinders works good... but it may take a couple days... keep at it. I've done it a couple of times. What ever you do do NOT try and use an impact wrench, you will bust the crank. Gregtruck above has the right idea. (although fredricks f750 airline is an intreging suggestion.)
Here's a good story (and it is true) an old codger around here had a stuck motor in his John deere tractor, he tried pennetrating oil, but it didn't work (the cylinders where horizontal and he couldn't get the oil all the way around the rings)... finally he put Coke in his cylinders filled them full and they broke free by the next morning... Not suggesting it, just telling a tale.
Old 12-04-2004, 11:26 AM
Just wanted to thank everyone for their help. When I mentioned putting motor oil in before I was using both marvels and PB blaster, ive let them work for almost two days now so will be trying to break her loose this afternoon. Ill post my results.
What a great site, thanks for everyones help.
Old 12-06-2004, 04:56 PM
dhermesc dhermesc is offline
dhermesc is starting off with a positive reputation.
Hope you are successful in breaking it free. If you get it turning over I think you're still looking at a rebuild to get it to run decent. I've seen several people successfully free up old tractor engines that gone on to run reasonably well, have never seen an automotive engine come back from the dead that way. Usually they barely run and if pushed they have a heart attack and throw a rod through the oil pan.
Old 12-06-2004, 05:05 PM
parks911's Avatar
parks911 parks911 is offline
parks911 is gaining momentum as a positive member of FTE.
Talking
Quote:
Take engine out
Preheat oven to 425* for 15 minutes.
Place engine in oven & cook for 3-4 hours.
Old 12-06-2004, 06:20 PM
Flip4ford's Avatar
Wouldn't microwaving it be faster???
haha (You made my day parks, thanks!!)
Old 12-06-2004, 06:26 PM
F150'89 F150'89 is offline
F150'89 is starting off with a positive reputation.
Quote:
Originally Posted by parks911
Take engine out
Also baste with 10W40 every 30 min
Old 12-06-2004, 06:49 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
and don't forget to sprinkle some donuts on it for better 360's and use the mini-donuts for tighter circles.....
Old 12-06-2004, 08:36 PM
well im happy to report that the engine was never frozen in the first place, the clutch pedal was not disengaging the clutch. The result was the engine not turning over and acting "frozen". Worked on her a few hours today and had it running.
Thanks for the help and the humor I needed both.
Old 12-07-2004, 12:35 AM
Quote:
Originally Posted by dhermesc
If you get it turning over I think you're still looking at a rebuild to get it to run decent. I have never seen an automotive engine come back from the dead that way. Usually they barely run and if pushed they have a heart attack and throw a rod through the oil pan.
I tend to differ on this subject. A "frozen" engine is ususlly an engine that has set idle long enough for condensation to rust the piston rings to the cylinder walls. If the engine is broken free properly and no rings are broken everything will do fine with some other precautions. First the engine needs to be turned by hand with penetrating oil only deep enough to cover the entire top of the piston. Spark plugs installed. Oil drained. This is to force the oil down around the rings and piston side. Draining the oil is to leep the oil pump from pumping crappy oil all through the engine. If everything seems to be turning OK I would remove the plugs and throw a little marvel mystery Oil in the cylinders and and add cheap motor oil to the crankcase. Let the battery/starter turn the engine a good bit. With no compression this will not be hard on the battery. You will be able to turn it enough so the oil light will go out meaning you have decent oil pressure with fresh oil. Ultimately removing the oil pan and cleaning it out would be the best idea. Depends on how mucky the old oil got and how dirty the engine was to begin with. The big idea is making sure nothing is dry or partially siezed before putting it to work.
Many things depend on HOW LONG the engine has sat. If it has sat say 20 years many seals may have hardened enough to cause need for replacement. The engine may run fine but leak a lot of oil. On the other hand if it has only been 6 or 7 years you may get away with compete revival. Also once a running engine is achieved a good dose of transmission fluid and/or Seafoam down the carb throat after warmup is a must. Possibly some Lucas in the crankcase as well.
I know Nicks problem is solved but I hope this info may be of use to someone at some point in time. Never know!
Get-R-Done
Greg
D60 adjustment star wheels frozen mountain dewd 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-18-2016 07:24 AM
2001 V10 Frozen gas line possible? 96mark8 1999 to 2016 Super Duty 20 02-02-2015 04:57 PM
a head question.... fordman67 1978 - 1996 Big Bronco 15 02-02-2014 01:54 PM
Frozen battery MustangGT221 Electrical Systems/Wiring 20 02-21-2006 11:13 PM
Is it possible my starter is frozen?? Bullet-Nose 1987 - 1996 F150 & Larger F-Series Trucks 5 03-11-2005 09:55 PM
Tags
350, engine, engines, free, freeing, froze, frozen, motor, oil, partially, running, start, tractor, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
