302 Distributor Woes - what fits what?
I have a 1984 302 without the computer or wiring harness and want to convert it to use a vacuum advance distributor and Dura-Spark 2 ignition. Upon removal of the original distributor (PN 64ZE12131AA)and comparision with the new one (P/N 6G17E2TE12127UA) it was discovered that the retro unit's shaft is shorter and larger in diameter - it just won't fit! Short of finding a mid-80"s computer and wiring harness to use the original distributor, what are my options? Is there a vacuum advance distributor that will work?
302 distributor woes
Went right out and bought a stock '81 distributor - it dropped in place with a little grease and bit of engine rotation. Suspect the one I started with was a first-generation Dura-spark compatible distributor. Thanks to all. I love this website - I usually get tech problems solved within 12 hours of my post.
Mike
Mike
xtal_01
09-13-2014 12:42 AM
74 F350 SCS
10-03-2012 07:05 AM
74 F350 SCS
09-25-2012 06:37 AM
Shane in WI
07-27-2010 02:13 PM
