Tranny Question... - Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader:
Tranny Question...
Old 12-03-2004, 04:49 AM
jbman100's Avatar
jbman100 jbman100 is offline
jbman100 is starting off with a positive reputation.
Tranny Question...
Did I ask this already????? A couple of years ago I was warming my truck up to come to work. I forgot the choke was on and dropped it into reverse while the motor was revving rather high. A couple of weeks later the tranny started slipping. What did I do to the tranny?
Old 12-03-2004, 11:59 PM
Hypoid's Avatar
Hypoid Hypoid is offline
Hypoid has a good reputation on FTE.Hypoid has a good reputation on FTE.
Probably helped the wear along a bit. If that's the only problem it had, you made out OK with that episode.
A few questions come to mind:
1) " a couple years ago"... Is it still slipping?
2) When was the last rebuild, or, band adjustment prior to the, uh, incident?
Mike
Old 12-04-2004, 12:32 AM
jbman100's Avatar
I stopped driving it right after that and the shortage of money kept me from working on it, so yes its still slipping.
I dont know. Probably before I bought the truck which was in 97.
Old 12-09-2004, 11:10 AM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
Tranny "slippage" can sometimes be attributed to low fluid level too. Check that out first and then move to the band, you can adjust those also. What tranny is it?
--Mike
Old 12-10-2004, 03:12 AM
jbman100's Avatar
The fluid was full last time I checked it, which is when I drovwe it last. Its the C-6.
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
