Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-02-2004, 06:49 PM
007bronco's Avatar
007bronco 007bronco is offline
Garage is empty, add now
007bronco is starting off with a positive reputation.
Propane 351M idles too fast
Hi, my 351M Bronco has a few issues.
-runs beautiful 1500 rpm or more regardless of timing
-starts good cold but will not idle without help til warm
-takes a bit to start warm with gas pedal depressed.
-will not idle below 800 rpm, it lopes, misses etc.
-will not run with brake pedal applied, disconnected and capped brake vac line had to bump up idle huge to run, runs same.
-has lots of power and is running on all cylinders.
-I think I have a vac problem but I may have a problem with the propane system as well-power valve is backed out almost all the way, idle screw on back of carb doesn't seem to do anything (IMPCO 425)- regular throttle body idle screw is all I can use to affect idle.
-Engine was rebuilt 6000 km ago-no smoke-no leaks-good power.
-truck works great if idle is 1200 rpm+
-has aftermarket 4bbl intake and impco adapter
-throttle response is quick with no bogging or pinging.
any thoughts?
thanks
007BRONCO
__________________
05 F-350 Lariat PSD 4x4 CC SB. SCT XCAL II, MBRP 4", Bilstein 5100's, 4" Donahoe racing lift
05 Escape
  #2 (permalink)
Old 12-03-2004, 12:05 AM
bigblocksix bigblocksix is offline
bigblocksix is starting off with a positive reputation.
i know nothing about propane but i would sugust taking it to a licenced propane mechanic and getting him to look it over, an hours labor to look over it could save ya a hole day of screwin arround
  #3 (permalink)
Old 12-03-2004, 07:12 PM
007bronco's Avatar
I hear ya, and I will consider it, I'll probably learn all there is to know after an hour with a good propane guru.
cheers
007BRONCO.
__________________
05 Escape
  #4 (permalink)
Old 12-09-2004, 02:18 AM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
You can use an 18" length of 1/2" or 3/4" copper tubing to locate vacuum leaks. hold one end you your ear and point the other end toward the engine, sweeping it around until you hear the leak. Careful not to get too close to the fan, belts or pullies.
Was the valvetrain rebuilt? Missing at low rpm could be sticking valves and would definitely cause a vacuum problem.
Tags
351, 351m, bronco, fast, ford, modified, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
