1992 Ranger 2.3 turns but will not start. No spark - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-26-2001, 07:51 PM
Jerryoke Jerryoke is offline
Jerryoke is starting off with a positive reputation.
My Ranger was running great when suddenly on the highway it just died. I towed it to local nationaly known brake/ muffler shop where a good friend is the manager. He narrowed it down (guessed in my opinion) to no spark and no fuel. He thinks it could be the crank sensor, the fuel pump or the ignition module. Is there any way to pinpoint the problem without replacing parts? If it helps at all, it will sometimes start and run for about 2 seconds before shutting off. It will not repeat this unless it sits for a day or two. I am not sure if there are different 2.3 engines availible but mine is fuel injection and has two sets of spark plugs and wires.
Thanks in advance
Old 11-26-2001, 09:21 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
Jerry, do you hear the electric fuel pump run when you turn the key on? It should run for about 3 seconds and then stop. You can also check for fuel pressure at the schrader valve on the fuel rail.
Your mechanic is right, if it's not the pump, then it may be the ign module or the crank sensor. There is a code scanner that can be hooked up to the engine, and that will tell which part is faulty.
Old 11-26-2001, 10:38 PM
No , there is no sound at all when I turn the key to the on position. I am leaning towards the pump. Right before it died, it seemed like it was starving for fuel. I would think if the sensor or ign module failed, it would have shut off instantly. I drove for maybe 1/8 of a mile just enough to get off the exit. If nothing else, the pump needs to be taken out to repair the faulty fuel gauge sending unit it has.
Thanks for your help. I will let you know how I make out.
Old 11-27-2001, 03:30 PM
2001rangeredge 2001rangeredge is offline
2001rangeredge is starting off with a positive reputation.
Post 1992 Ranger 2.3 turns but will not start. No spark
I had a 91 ranger that had a similar problem although it was a 3l. It turned out to be the relay for the fuel pump. It was located under the fuse box in the engine compartment.
Old 11-29-2001, 03:08 PM
ford87ranger2002 ford87ranger2002 is offline
ford87ranger2002 is starting off with a positive reputation.
it also could be that your fuel filter could be pluged. you may need to replace this to make it run
Ford87ranger2002
Old 12-03-2001, 10:54 PM
It was the fuel pump. Its back to running great. Thanks to all for your help.
Old 12-04-2001, 04:51 PM
firemedic1027 firemedic1027 is offline
firemedic1027 is starting off with a positive reputation.
Old 06-19-2014, 08:40 PM
SPrice505 SPrice505 is offline
SPrice505 is starting off with a positive reputation.
So I had a friends 92 Ranger in the shop with the fuel pump not buzzing on.. I checked the inertia switch and fuses which were good. When I got to the wires at the pump its self there was no power... after tracing wires for a while I just ended up putting power straight to the pump from the battery and got the truck running just fine.. My question is if I can run it like this? I have a 10amp fuse and toggle switch in the circut
Old 06-20-2014, 02:07 PM
92Ranger123 92Ranger123 is offline
92Ranger123 is starting off with a positive reputation.
Old 06-22-2014, 10:51 PM
oscar2 oscar2 is offline
oscar2 is starting off with a positive reputation.
O2 sensor
1997 ford ranger 2.3L with 63K only
i just puy it with check engine light code P0141 and P0136
O2 bank1 sensor 2
i cant found any after the catl
need help
97 ranger 2.3 crank no start Tnewton12313 Ranger & B-Series 30 08-25-2016 02:04 PM
93 2.3l ranger wont start edgar gonzalez Ranger & B-Series 3 01-02-2016 01:47 AM
1987 Ranger 2.3L has virtually no power OPC1987 Ranger & B-Series 11 12-28-2015 09:25 PM
2.3l no spark at two plugs samiam1017 Ranger & B-Series 6 03-24-2014 05:35 PM
help! 2.3 wont start dsteph79 Ranger & B-Series 3 05-24-2010 01:14 AM
Tags
1992, 23, 87, 91, 92, crank, died, eec, ford, fuel, ranger, relay, spark, start, wont, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
