Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
UPDATE to Harley Making Noise
Old 12-02-2004, 06:53 AM
jcjc2u's Avatar
jcjc2u
jcjc2u is offline
I've now noticed when It makes the flutter sound. Its when the automatic transmission is switching gears. Mainly from around 50mph to 60mph. Some times a lower gear though. I dont feel much of a jerk of the truck. Maybe a hint of lag.
Some would call it a grinding sound maybe. Sounds like its coming from more the middle to right back end. Any ideas fellas?
ps- im watching the rpms at around 2000 and the noise occurs while there dropping to about 1500 while accelerating.
Old 12-04-2004, 10:38 AM
jcjc2u's Avatar
jcjc2u
jcjc2u is offline
Thought I would let the readers know... Ford says I need my tranny flushed. The fluid is broke down. And after reading on here I see that is typically the problem. Im getting that done monday... I will let you know.
Old 12-08-2004, 06:32 AM
jcjc2u's Avatar
jcjc2u
jcjc2u is offline
Got the Fluid changed per the specs. Using the decoder I got off of this site to find out which tranny I had.
That fixed it!!!
Old 12-08-2004, 08:32 AM
yysenhimer's Avatar
yysenhimer
yysenhimer is offline
How many miles did you have on the tranny fluid? I changed mine when I bought my truck at 22K and then again at about 40K. I talked to a tranny guy and he said it is better to change the fluid more often than to use synthetic fluid. Synthetic is better, but people who use synthetic fluid tend to go longer length of time between changes.
Get yourself a Factory Tech valve body, and a 4X4 transpan that has a drain plug. It will make future changes a lot easier and make your trans shift better. Glad your problem was minor.
mjpaldino
Modular V8 (4.6L, 5.4L)
04-20-2012 06:04 PM
catan70
1997 - 2003 F150
01-23-2010 09:35 PM
rootbeerford
34
07-23-2007 05:35 PM
windshadow
1999 to 2016 Super Duty
10-29-2006 08:22 AM
Mexray
1978 - 1996 Big Bronco
04-11-2002 02:02 AM
Quick Reply: UPDATE to Harley Making Noise
