Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 12-02-2004, 06:53 AM
jcjc2u jcjc2u is offline
Garage is empty, add now
jcjc2u is starting off with a positive reputation.
UPDATE to Harley Making Noise
I've now noticed when It makes the flutter sound. Its when the automatic transmission is switching gears. Mainly from around 50mph to 60mph. Some times a lower gear though. I dont feel much of a jerk of the truck. Maybe a hint of lag.
Some would call it a grinding sound maybe. Sounds like its coming from more the middle to right back end. Any ideas fellas?
ps- im watching the rpms at around 2000 and the noise occurs while there dropping to about 1500 while accelerating.
  #2 (permalink)
Old 12-04-2004, 10:38 AM
Thought I would let the readers know... Ford says I need my tranny flushed. The fluid is broke down. And after reading on here I see that is typically the problem. Im getting that done monday... I will let you know.
  #3 (permalink)
Old 12-08-2004, 06:32 AM
Got the Fluid changed per the specs. Using the decoder I got off of this site to find out which tranny I had.
That fixed it!!!
  #4 (permalink)
Old 12-08-2004, 08:32 AM
yysenhimer yysenhimer is offline
yysenhimer is starting off with a positive reputation.
How many miles did you have on the tranny fluid? I changed mine when I bought my truck at 22K and then again at about 40K. I talked to a tranny guy and he said it is better to change the fluid more often than to use synthetic fluid. Synthetic is better, but people who use synthetic fluid tend to go longer length of time between changes.
Get yourself a Factory Tech valve body, and a 4X4 transpan that has a drain plug. It will make future changes a lot easier and make your trans shift better. Glad your problem was minor.
__________________
'05 F250PSD CC
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
