Max tire size on 1997 2wd ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-01-2004, 11:04 PM
98superstock 98superstock is offline
98superstock is starting off with a positive reputation.
Talking Max tire size on 1997 2wd ranger
My son just picked up a 1997 2wd ranger. The stock tires are 215/70/15. What are the largest tires he can fit onto the 14 inch rim that will not rub anywhere, with absolutely no modifications of any kind? Sorry if the post seems redundant but I tried a search and couldn't seem to get the information I wanted. Thanks!
98Superstock
2003 F350 Superduty Powerstroke Crew Cab Long Box
Old 12-02-2004, 01:55 PM
Nalow Nalow is offline
Nalow is starting off with a positive reputation.
Is it a 15" or a 14" rim? You stated both...
If it's a 15" rim, I'd go with a 235/70/15... You'll have a lot of options in that size.
I wouldn't think it would rub. And if it does, probably not anything too bad.
If it's a 14" rim, a 225/70/14 would work with no rubbing.
Hope this helps.
Old 12-02-2004, 04:42 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
I just went from 225/70/14 to 215/75/15 on my 94 SuperCab and it works great.....can't fit a fully inflated spare going any bigger-like 235/75/15, so I guessed okay there.
I believe on the 93-97 trucks, you can fit a 30.5 or 31 on the 15" tires and get by.
Old 12-02-2004, 05:37 PM
Quote:
Originally Posted by 98superstock
My son just picked up a 1997 2wd ranger. The stock tires are 215/70/14. What are the largest tires he can fit onto the 14 inch rim that will not rub anywhere, with absolutely no modifications of any kind? Sorry if the post seems redundant but I tried a search and couldn't seem to get the information I wanted. Thanks!
98Superstock
Sorry guys I did mistakenly mention two rim sizes. The rim size is 14".
Old 12-02-2004, 10:50 PM
ktplotts ktplotts is offline
ktplotts is starting off with a positive reputation.
I'm running 235/75/15's on mine, originally had 215/70/14's i think. Its a 96 reg cab 2wd btw.
Old 12-03-2004, 04:40 AM
grease monkey's Avatar
grease monkey grease monkey is offline
grease monkey is starting off with a positive reputation.
I looked all over for a tire for that rim. The problem it isnt the most popular rim size and all the tires that fit it where car all season tires. The tallest tire I can find that will fit that rim is a 225/70/14. I dont know what kind of tire you are looking for. If you live where it snows I recomend the Cooper Discover At in that size. They are not to bad in price and they are great in the rain and snow. If you want to spend more try the Bridgestone Dualers At.
Old 12-03-2004, 03:57 PM
dwildmanj dwildmanj is offline
dwildmanj is starting off with a positive reputation.
I, too, run 235/75/15's on my 97 Ranger 2wd. The truck sits as high as an Explorer, too. Had 'em on it when I found it and still had the 14" spare underneath. Went to a junk yard and found a 15" rim for 10 bucks, 10 bucks for a used tire at a repair place that I've used, and now I have the extra 14" spare that I don't know what to do with.
390 ignition upgrade opinions? 1975FordF250 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-10-2015 11:09 AM
98 ranger a/c question chris66 Ranger & B-Series 7 07-16-2014 09:25 PM
Max tire size on a 2 inch lift? tkiner 1999 to 2016 Super Duty 4 03-15-2010 12:11 PM
1997 ranger tow specs jgmai Ranger & B-Series 8 09-03-2007 03:36 PM
2wd Tire size mattimeo 1973 - 1979 F-100 & Larger F-Series Trucks 19 01-19-2007 10:46 PM
Tags
14, 1997, 225, 2wd, 70, ford, max, ranger, size, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
