Vibration Fixed, COMPLETELY....had to spend some $$ though!
The 4.56s aren't bad at all on the highway. At 70 mph, I'm only seeing 2300 RPM. At 80, I'm around 2700 RPM. Remember this is on the stock 32" 4WD tires. If I had a 2WD, I would have gone with a 4.10. I am still seeing 15 mpg on the highway at 80! Around town, I am getting nearly 1 mph BETTER. The truck actually accelerates now, especially with a 6,000 lb trailer. I downsized to my F-150 from a 04 F-350 w/ the 6.0L PSD. I had a box (module) on the 6.0L, which added over 200 ft/lbs at 2,000 RPM, so pulling a 6,000 lb trailer at 70 mph, turning 2000 RPM was a dream. The truck would pass with the trailer on a two lane road WITHOUT having to downshift or even unlock the converter. SO, you can imagine the disappointment going from that to the weak power of a gasser. The 4.56s helped improve this weakness a little....at least I can use O/D at 70 mph now when towing.
Maybe it is a balancing issue, but my guess is just a bad production run or production period on them. Maybe they weren't handled properly before install and had minor bends in them? I'm not sure. My truck was smooth at 90 mph too even with the 4.56s, but fall down to 80 and it was bad, so it only occurred at specific driveshaft RPMs. Now with the carbon fiber shaft, the truck is silky smooth at ANY MPH.
Originally Posted by ITDave
Is there going to be an announcement on December 8th or is this yet another tease?
Originally Posted by Dunk
I'm not sure I'm buying this driveshaft problem unless it specific to the driveshaft builder Ford is using. There's an awlful lot of allot longer driveshafts than what a Scab takes out there spinning just fine. If balancing them isn't the problem and critical mass problem is then what you would be feeling is a driveshaft whip.
Chinstar,
Ahhhh....good info!!! I didn't know that. I assumed that all F-150s used a one piece. You've got me stumped on the 2WD. It all depends on which one may be causing the vibration. The rear portion is probably the longest, right? If so, and your vibration is speed sensitive (not RPM) and happens from 45-60 mph roughly, it's 99% most likely your driveshaft. Typically 2 piece driveshafts connect to each other at the carrier, so they can be replaced independently. I would contact PST (www.pstds.com) to discuss at least an aluminum replacement. It may be pricey since you have twice as many U-joints.
Hey guys didn't have a vibration until I got on here and started reading about other people having them and then at around 3000 miles I started getting one during acceleration between 50 to 70mph and then it goes away once I come up to speed. Called my dealer yesterday and they said bring it in because they new all about the vibration in the F150's coming from the driveshaft and would take a look at it.
I have an appointment at the dealer for Saturday. My sales guy said that the Ford Factory guys told him it has to do with the two part drive shaft and they are going to have a fix for this.
I will let you all know what I find out.
