1993 Ranger rear end swap
Old 12-05-2001, 07:23 AM
jcowin's Avatar
jcowin
jcowin is offline
Post 1993 Ranger rear end swap
Currently my 1993 Ranger (2.3L) has a 7.5" rear end with a coventional differential. I have heard that same year Ford offered a Traction-lok(sp?) rear end. I am also told the 1995 rear end is interchangeable. Does anybody know if either of these things is true? If so how hard is it to swap them out? I live up north in South Dakota and I can't get around half the time in my Ranger but I can't afford a new truck right now. Thanks for the help
Old 12-06-2001, 08:21 PM
badranger302's Avatar
badranger302
badranger302 is offline
That is the beauty of a ranger...Ford did not change alot. Yes your rearend will swap but why? I have built 3 5.0 rangers and yet to blow out a 7.5 rear.. Try adding a little weight when traction gets low..
Old 12-07-2001, 07:43 AM
rabidranger's Avatar
rabidranger
rabidranger is offline
I have a lock rite and 4.10's in my 7.5" rear, no probs. I just have to get a D44 for the front tho, 9 blown axle shafts leads to believe the dana 28 ain't up to the task...
Old 12-13-2001, 02:01 PM
ianjay42's Avatar
ianjay42
ianjay42 is offline
Greetings:
The rear ends do interchange, but be cautious about what you come across. Read the codes and make sure you are getting an appropriate gear ratio. The owner's manual will tell you how to figure out which rear end ratio you have. When the pinion shaft sheared in my '83 4 cylinder Ranger (quite a surprise given that it was hardly a torque monster), the wizards at my garage stuck another rear end in - it was obviously completely wrong for my engine and transmission. I couldn't use fourth gear unless I was going at least 60 mph. My '90 2.9 also easily spins the rear tires and my NEW garage says that there is a kit which will convert what I have to a locking axle. This would cost about $600 CDN. Given that the truck has 315,000 km on it, I have decided to go with an old lateral file cabinet in the back and a little less peddle now that things are getting slippery. Make sure you know what you're buying before you lie in the mud to change the rear end out. The wrong gears really spoiled my '83.
Old 12-18-2001, 05:48 AM
Splash302HO's Avatar
Splash302HO
Splash302HO is offline
What setup do you have in your 5.0 Rangers??
I have a 93 Splash with a 5.0L HO and the stock 7.5 with 3.73 gears.
They are opening up 1/8 mile drags in the spring and I want to run without trashing the 7.5.
Old 12-18-2001, 08:01 AM
Ken00's Avatar
Ken00
Ken00 is offline
u8mylnch
New Member Introductions
03-04-2015 03:21 PM
jtlinn1975
04-14-2014 04:37 PM
kentuckyredneck
01-06-2014 06:59 AM
meborder
1997-2006 Expedition & Navigator
37
12-18-2013 10:24 PM
Oxfordrider
38
11-05-2012 11:51 AM
Quick Reply: 1993 Ranger rear end swap
