1993 Ranger rear end swap - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-05-2001, 07:23 AM
jcowin jcowin is offline
jcowin is starting off with a positive reputation.
Post 1993 Ranger rear end swap
Currently my 1993 Ranger (2.3L) has a 7.5" rear end with a coventional differential. I have heard that same year Ford offered a Traction-lok(sp?) rear end. I am also told the 1995 rear end is interchangeable. Does anybody know if either of these things is true? If so how hard is it to swap them out? I live up north in South Dakota and I can't get around half the time in my Ranger but I can't afford a new truck right now. Thanks for the help
Old 12-06-2001, 08:21 PM
badranger302 badranger302 is offline
badranger302 is starting off with a positive reputation.
That is the beauty of a ranger...Ford did not change alot. Yes your rearend will swap but why? I have built 3 5.0 rangers and yet to blow out a 7.5 rear.. Try adding a little weight when traction gets low..
Old 12-07-2001, 07:43 AM
rabidranger's Avatar
rabidranger rabidranger is offline
rabidranger is starting off with a positive reputation.
I have a lock rite and 4.10's in my 7.5" rear, no probs. I just have to get a D44 for the front tho, 9 blown axle shafts leads to believe the dana 28 ain't up to the task...
Old 12-13-2001, 02:01 PM
ianjay42 ianjay42 is offline
ianjay42 is starting off with a positive reputation.
Greetings:
The rear ends do interchange, but be cautious about what you come across. Read the codes and make sure you are getting an appropriate gear ratio. The owner's manual will tell you how to figure out which rear end ratio you have. When the pinion shaft sheared in my '83 4 cylinder Ranger (quite a surprise given that it was hardly a torque monster), the wizards at my garage stuck another rear end in - it was obviously completely wrong for my engine and transmission. I couldn't use fourth gear unless I was going at least 60 mph. My '90 2.9 also easily spins the rear tires and my NEW garage says that there is a kit which will convert what I have to a locking axle. This would cost about $600 CDN. Given that the truck has 315,000 km on it, I have decided to go with an old lateral file cabinet in the back and a little less peddle now that things are getting slippery. Make sure you know what you're buying before you lie in the mud to change the rear end out. The wrong gears really spoiled my '83.
Old 12-18-2001, 05:48 AM
Splash302HO Splash302HO is offline
Splash302HO is starting off with a positive reputation.
What setup do you have in your 5.0 Rangers??
I have a 93 Splash with a 5.0L HO and the stock 7.5 with 3.73 gears.
They are opening up 1/8 mile drags in the spring and I want to run without trashing the 7.5.
Old 12-18-2001, 08:01 AM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
New from OK transplant from SD u8mylnch New Member Introductions 2 03-04-2015 03:21 PM
Newbie from South Dakota jtlinn1975 New Member Introductions 3 04-14-2014 04:37 PM
Traveling across state lines with trailer kentuckyredneck General NON-Automotive Conversation 6 01-06-2014 06:59 AM
Car Shopping meborder 1997-2006 Expedition & Navigator 37 12-18-2013 10:24 PM
Top Speed on a 1954 F100 Oxfordrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 38 11-05-2012 11:51 AM
Tags
1993, 23, change, end, ford, ranger, rear, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
