Secondly, you may want to check in with the PSD forum group, propably get a better answer than what I'm about to say..... How about water or moisture in the fuel system
Might want to find something to clean youre injectors aswell....if you dont find anything you wanna buy, try running a quart of ATF thru the fuel system in your next fill up. The ATF should help clear anything out of your injectors that may be causing them to be restricted..
