79 F150 4x4 Ignition wiring
I installed a new module anyway, cuz they always go bad. I put it on, ran for a couple of days. Now today it died without spark at work today. I ran all new wiringfor the ignition system from the module to the distributor and coil. The wires were getting pretty old do I needed to do it anyway. Still nothing, and the coil is good. There is power to the module. I think it went out again. No parts stores around here can test them. And we have almost have every parts but none say they can test them. Oh yea, I tested the wire to the oil pressure sender and it was pulseing. Wierd, the gauge worked though.
the coil is good
Do you have pulsing power on the - of the coil when you crank the engine?
nothercrash
02-27-2014 08:49 PM
HatleyT
07-06-2012 11:40 AM
