Poor Heater - typical or not?
Hi,
The weather has turned colder over the past few days and I have noticed that the temp of my heater never gets "hot" - it seems to old just take the chill out of the air. Today its about 35 degrees out and the temp gauge never gets above N (in Normal) on my 25 mile trip to work.
A week or so ago it over heated because the previous owner had wired the electric cooling fan wrong. I was able to refill it imediatly and fixed the fan wiring that eve.
So... could the over-heat have nackered the thermostat or the heatercore? I don't remember if the heater was ever any good (only had the truck 10 days). Are they prone to airlocks in the heater matrix or do they self bleed?
I'm going to get a new thermostat so see if that helps but how well do your heaters work - I know there is a great variation in temperatures in the States but I would expect it to be as warm as a hand dryer in a Restroom when it has warmed up???
Cold and Frustrated!
Simon
Simon
Typically, the heaters in the Broncos are quite efficient. I have (for no other reason than I was curious) run around in 20 degree weather in shirtsleeves in my own. If the over heat purged a lot of coolant, you may need to check the level again at the radiator not the expansion tank. If the level in the radiator drops enough, the system will not draw from the expansion tank and you will end up an almost full exapnsion tank and a system full of air pockets. If topping it off doesn't help, try starting with a cold engine and leaving the radiator cap off while you let it idle. This should allow the system to purge any air pockets and you can then top off once it has reached operating temp.
We just replaced the thermostat in son in law's F150 for the exact same reason. All was fine until he sprung a leak and ran the truck a bit hot. Fixed that and it seemed fine until cold weather hit and he complained of getting no heat. New thermostat and all was toasty again. (Though I still don't think he comprehends exactly what it is the "TEMP" gauge readings actually mean)
Apparently sometimes running an engine hot can toast a thermostat. I've had it happen to me once or twice too.
Yeah overheating will ruin the "temper" in the spring and change the temperature "value" required to make the thermostat open. One way around running the risk of this problem is with a "wax core" thermostat. The thermostat is just as the name would imply, a wax of sorts is encased in the t-stat and when the proper temp is reached the wax melts allowing the t-stat to open. Nice thing is, if the truck does overheat, the wax just stays melted. The additional heat won't affect the spring temper as there is no spring to malfunction. When everything cools down the wax solidifies again and the process starts over.
