propane?
Old 12-24-2004, 11:55 AM
brown79's Avatar
brown79
brown79 is offline
propane?
my unit (79 f150 2wd 460 auto) runs on propane. i want more horse power but the propane here is 58% cheaper than 87 octane gas. any ideas?
Old 12-24-2004, 01:20 PM
ranger429's Avatar
ranger429
ranger429 is offline
Change it back and start running gas. If you want more power you have to give up something.
Old 12-24-2004, 01:22 PM
84-250's Avatar
84-250
84-250 is offline
rebuild the engine with higher compression- 11:1 or around there
rebuild the engine for twin turbos (forged internals)
Old 12-25-2004, 10:40 AM
canda250's Avatar
canda250
canda250 is offline
I have 2- 1979 Ford trucks on propane. If your truck has been on propane all its life like mine, the heads and carb will be damaged and have to be replaced along with any other rubber fuel line parts. I need a rebuild on the bearings on my 302 and intend to put mine on unleaded during this process. I live in OK and propane is not cheap.
Old 12-25-2004, 12:23 PM
ivanribic's Avatar
ivanribic
ivanribic is offline
This is what I would do if propane was that much cheaper than gas. I believe propane is around 110 octane so you can run extremely high compression on it. Some of the guys with propane powered competitoin buggies are running 13:1.
Old 12-25-2004, 11:18 PM
Phinxter's Avatar
Phinxter
Phinxter is offline
Actually propane is 118 octane. You could go higher than 13:1, Cummins makes 2 versions of it's B series diesel converted to run on either LPG or CNG and if I'm not mistaken they are around 18:1. You also need to advance the timing running propane and you could even have the Distrib advance recurved.
Old 01-01-2005, 01:37 AM
hot1958's Avatar
hot1958
hot1958 is offline
hey guy's,does any body know any good book's or source's for info on installing and tuning propane.any help would be great,thanx/scott.
Old 01-01-2005, 02:22 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Old 01-01-2005, 10:14 AM
hot1958's Avatar
hot1958
hot1958 is offline
hey dave,thanx/scott.
79sparky
10-09-2013 04:52 AM
mokicoolcruz
04-13-2008 10:14 AM
fishindave11
04-22-2007 10:34 AM
CrewCabCOE
Alternative Fuels, Hybrids & Mileage
04-03-2005 01:21 PM
mcrank
1978 - 1996 Big Bronco
05-31-2002 02:08 PM
Quick Reply: propane?
