Front end Alignment - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front end Alignment
Old 11-29-2004, 06:11 PM
JimBrazil JimBrazil is offline
JimBrazil is starting off with a positive reputation.
Front end Alignment
Does anyone have the front end alignment specs for a F250 SD 2005 4WD? My truck is really wearing the tires on both the inside and outside but the tire store I prefer to use doesn't have the specs. The truck is ok using 04' specs.
Jim Brazil
Old 11-29-2004, 06:17 PM
bdjupiter's Avatar
bdjupiter bdjupiter is offline
bdjupiter is starting off with a positive reputation.
If it is wearing on both the inside and outside of the tire I would check my tire pressure to make sure it is high enough. A underinflated tire will wear like that. Sorry I don't have the specs for you but I thought maybe you could check that before you spent money on an alignment.
Old 11-29-2004, 06:42 PM
SRD4X4 SRD4X4 is offline
SRD4X4 is starting off with a positive reputation.
Agree with bdjupiter,alignment will wear 1 side or another.Tires should be rotated every 5-6,000,if they were run low then sooner.
Old 11-29-2004, 06:54 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Jim,
I know of a website that has the spec's but can't remember it right now
(fordfleet ) They had all the spec's for 05's
Rich
Old 11-29-2004, 07:02 PM
1olddog2 1olddog2 is offline
1olddog2 is starting off with a positive reputation.
wait a sec. if this an 05 , why r u tooking it some where other to the dealer ? i have an 05 with 5000 miles and tire problems but i did need an alinement the steering was slight off center , ford had to call in to hq 4 the info
Old 11-29-2004, 07:12 PM
Don't take this wrong; From experience most mono-beam trucks have 1/4" too much toe-in from factory,center steering on a mono-beam has nothing to do with alignment( has seperate adjustment sleeve) and coils or leafs have no effect on mono-beam.
Old 11-29-2004, 07:46 PM
FortyFords's Avatar
Srd4x4 ,you are correct
I'm not thinking tonite.
He needs to get it to ford for the spec's
Rich
Old 11-29-2004, 11:21 PM
I would rather not take anything to our local Ford dealer unless absolutely necessary. I purchased the truck with 1400 miles on it for about 22% off retail and didn't have to pay all the extra dealer prep and processing (extra dealer profit) fees. The truck has 2000 miles on it and shouldn't be showing this kind of tire wear.
Jim Brazil
Old 11-30-2004, 11:26 AM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
In the recent past, Ford warranty covers one alignment up to 12,000 miles. I would think that rings true with '05.
Check OASIS and see if a warranty alignment has already been done. Dealer should be happy to provide this info.
Old 01-15-2005, 09:41 PM
mcchicago mcchicago is offline
mcchicago is starting off with a positive reputation.
o5 alignment specs
Quote:
Jim Brazil
Just got my '05 F-350 back from the dealer. I had a drift to the left and the proper alignment required new adjusters on the left side to get the caster/ camber/ toe correct. Without the new adjusters they couldn't get the alignment in spec. FYI the Ford Specified Ranges are: Camber -.08 to 1.3 Caster 1.5 to 5.5 Toe -0.11 to 0.14.
According to the data sheet left in the truck the Left Front Toe was -0.43, Right Front toe was -0.45 and the total toe was -0.88.(out of specs) After the alignment total Toe was -0.01. Truck rides straight as an arrow.
BTW dealer was Joe Rizza Ford in Orland Park, IL. They did a nice job. Truck has 3000 miles, and this was a warranty repair.
Front end alignment 87&97Aerostrar Aerostar 2 08-20-2015 10:50 AM
2wd ranger xlt 1994 alignment specs quartermilecamel Ranger & B-Series 0 04-22-2015 02:55 PM
85 F150 4WD Front-End Alignment? Sean_Reno 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 02-09-2015 01:47 AM
Front End Alignment Factory Settings stirfrysteve Ranger & B-Series 4 09-11-2011 08:31 PM
Volare Clip alignment specs jwcnj45 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-02-2004 11:43 AM
Tags
2008, alignment, data, escape, ford, spec, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
