HP calculations needed!
Could I prevail upon one of you guys to figure out the horsepower of my truck so I can impress someone? Pleeeaaaassseeee? *grin* I'm emailing him now.. so if any of you guys are on, please let me know what you need to know about my truck to figure that out.
Thanks!
Thanks!
He'll probably just laugh at you, computer determined horsepower numbers are usually suspect by everyone that has anything to do with engine building. Some programs can be pretty accurate, however, the condition of the engine has a lot to do with it. Keep in mind this will be at the flywheel, with everything tuned to perfection.
I need:
The heads you're using.
The intake.
The carburetor.
Exhaust (headers, mufflers?)
Compression ratio - dont guess here, give pistons used if possible and combustion chamber volume
Bore & Stroke (include any overbore)
Camshaft manufacturer and part number. Maybe I'll have it on file, maybe I wont. If I dont I'll ask you to get specs on it. More on that later if I dont have it on file.
I need:
The intake.
The carburetor.
I need:
The heads you're using. 428 C8AE-H
The intake. Edelbrock Performer 390
The carburetor.Edelbrock 1406
Exhaust (headers, mufflers?) Tri-Y Headers, Flowmaster 30's, dual 3 inch
Compression ratio - 10.5:1
Bore & Stroke (include any overbore) 4.13 x 3.98
Camshaft manufacturer and part number. Melling MTF4
Can you also figure it using the same, but with the Holley 770TA carb?
ThanK you so much!
ThanK you so much!
Originally Posted by eriksf250
how much power and torque should i be putting out of my freshly rebuilt 390 with med riser 4v intake with a 2" swirl torque carb spacer and a 600 cfm Holley, 9.5 comp., crane cam with a .458/.484 lift, headers, dual 2.5" exhaust with Flowmaster 50s? Desktop Dyno figures are appreciated.
--Mike
Well, the 971 is an EXTREMELY mild cam, with less duration than the stock cam. And its still got more lift than the cam you specified. It would idle very smooth, but it would ping like crazy since its meant for low compression apps.
We cant run any desktop dyno numbers without the exact specifications for your cam. We just cant, they would be too far off.
The only cam that comes close is the Edelbrock Performer cam, it has .460" intake lift and .480" exhaust lift. With that, you're looking at 284hp @ 4000rpm, and 455ft-lbs @ 2000rpm. You could definately use a bigger cam. If you swap it to the Crane 343941, which is very popular around here (I use one myself) you're looking at 331hp @ 4500rpm, and 416ft-lbs steady from 2500rpm to 3500rpm. Torque curve is extremely flat.
You could also benefit a lot from porting your heads.
