You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well I've stuck alot of money($10,000+) in my truck I guess you could say I love doing things like this but Its time for somthing new I'll still be help out any way I can with the chapter. I'm ether trading the truck in or selling it. A good friend mine is an auto mechanic and has always told me buy forgien and buy new when ever possible so I'm cutting my losses and getting out (this is a hint of what I'am buying and its not a truck). not there is really anything wrong with my truck but it has hit me hard in the pocket book this last year. So If anybody looking for a truck(or another truck) e-mail me and please let me know if the chapter would still like to have me as a member.
being a member of the chapter doensn't require you own one, and what you have learned through having yours is valuable information. As I see it, there is no reason for you to not be allowed... not that I knew of any restrictions on being a member anyway. You still are the same, no matter what you drive, and I can't imagine your participation changing only because you had to let it go.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
yeah But It started small and built it way up there. I might have it all worked out but I'll never see my money out of it. so its ether sell it and cut my losses or keep it for life. Ifigured out my cost and I just don't like the idea That I spent that much money on a 13 year old truck.
I had to do that with my old 75 highboy. I had so much money dumped into it, and still had a motor that was substandard, trans that was temperamental, steering that needed a new box, the old one nearly broke my knucles before the hose blew, brakes that needed rebuilt, again, bad transfer case, front and rear axles had different gear ratios due to an individual who didn't know what they had, claimed it a 4.10, was a 3.73, but I was in a tough spot, had to have it moving, lets see, more work, the body had a bad cab mount, should have replaced it when I did the other, wiring problems, the steering column was the standard garbage, on and on and on.... I just decided to quit while I was behind, because I couldn't see how or why I could get caught up.
__________________
i have got 4000 in my 34 year old truck soon to be more.
__________________
Iowa chapter member
FTE supporter
If you can read this, thank a Teacher
if it is in english, Thank a Soldier !
Currently truckless and Laid Off!
but i am happy!
Oh please don't even get me started on how much I have into trucks it gets real depressing real fast but a hint I have more into my truck than my house.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
it depends on what you have gotten back from them, mine was still about as good as a parts truck, and needed all that. I unloaded it cheap, because that was what it was worth. At least you have something to show for your investment.
__________________
new engine 1400
new trans 200
tires 300
alt 30
pwr steer pump 50
gearbox 50
water pump 50
carb 200
chrome 200
dizzy 50
rims 50
stero 150
misc gauges 200
speedo cable 25
misc everything else 750
seeing the look on a ricers face when i leave him at the light
priceless !
__________________
Iowa chapter member
FTE supporter
but i am happy!
