Ford's C6 hd pinion set - Ford Truck Enthusiasts Forums
Old 11-28-2004, 08:21 PM
tastyklair tastyklair is offline
tastyklair is starting off with a positive reputation.
Has anyone here used the Ford HD 6-Pinion wide ratio gear set kit. Ford racing lists it and says
"This kit adapts gear train componennts from the new 4r100 trans to all c6 trans. The 6 pinion planet assemblies provide 2.72:1 low and 1.54:1 intermediate ratios as the discontinued m-7398-c gear set, while increasing torque capacity by 43%. Kit includes the hd #5, #7, #8, and #9 needle bearing components. Provides drag racers with more acceleration and tow vehicles or motor homes with more pulling power without changing axle ratios. Note: No machining is required on m-7398-f kits!"
What differences have you noticed if any one has used this. What are the stock ratios in my 79 c6?
Old 11-28-2004, 09:17 PM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
I haven't used the kit. I have looked into it though. Stock C6 ratios are 2.46, 1.46, 1.00.
Dana 44 Catastrophic Failure rat_6 Clutch, Transmission, Differential, Axle & Transfer Case 10 02-03-2016 04:55 PM
Ford F250 Dana 44 HD Front axle, 4.10 ratio scarey1 Ford Truck Parts for Sale 1 09-14-2015 11:41 PM
kysor a/c system jaker65 Large Truck 4 08-28-2015 05:52 AM
C6 to E4OD swap........Complete! David85 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 31 04-27-2008 05:52 PM
C6 mods tastyklair Clutch, Transmission, Differential, Axle & Transfer Case 0 10-19-2004 03:45 PM
Tags
ford, gear, m7398c, m7398f, pinion, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
