If you'd been able to get ahold of me, I could have been there in 20-30 minutes, Roger. I was in Pleasantville and stayed the night. Actually I was in Hartford for a bit, even closer.
Why'd you have to disassemble the trailer brakes for?
the lining separated from the shoe, efectively applying the brake, heating the tire and hub, eventually blowing the tire. After I blew the tire a second time, I fugured it had to be something, and sure enough, the hub was warm. I didn't have a decent jack, and Flying J doesn't have them, so I took my chances and headed over to the Super Wally over to Altoona, got one, and found the lining when I pulled the drum. Another example why I don't like glued on crap in critical locations... Just ask me about quad 4's sometime and glued on crap...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
it wouldnt have, i am giving it a few more days then i am updating the map. no fear opie is near
__________________
Iowa chapter member
FTE supporter
If you can read this, thank a Teacher
if it is in english, Thank a Soldier !
Currently truckless and Laid Off!
but i am happy!
