87 Ranger fuel gauge sending unit - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-26-2004, 01:03 AM
gregbr gregbr is offline
gregbr is starting off with a positive reputation.
My gas gauge sending unit is erratic around 1/4 tank in my 87 Ranger 2.0 carb engine. I have searched everywhere except the dealer (for obvious reasons) and can't find a replacement sender unit. Where do you get one?? Greg
Old 11-26-2004, 09:17 AM
G2IC_Wraith G2IC_Wraith is offline
G2IC_Wraith is starting off with a positive reputation.
Do you have Advanced Auto Parts in your area? I have an 88' 2.3L FI that they did carry when I asked about it. Didn't buy it since the common problem of fuel in the float was all that was wrong with mine.
Old 11-29-2004, 06:23 AM
I have all the leading parts houses around, but have not asked in person. I checked most of them on the their web pages. I will call and check, maybe they don't list everything on the web. Greg
Old 11-29-2004, 10:59 PM
MSRanger MSRanger is offline
MSRanger is starting off with a positive reputation.
I had an '88 Ranger new from '88 to 2000.
The fuel senders tended to go bad a little at a time.
First mine worked fine, then as it aged, it would drop a quarter tank in the first 20 miles after fillup, then work fine from there.
Later it would drop a half tank within 20-30 miles of fillup.
In the '88 with fuel injection, the sender is integral with the fuel pump, in the top of the tank, and it was over $100 for a new replacement. Local tank/radiator repair guy advised against used ones, which may not last much longer than existing.
I got good at always filling up the tank, and refilling again at 280 miles on the tripmeter. I went the second 100K miles that way. Of course I was the only one that drove the truck.
Tags
87, fuel, gauge, level, ranger, sender, sending, unit, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
