Bw 1356 electric shift conversion
Backfire, I have read some about this and it seems that you should probably get a manual shift xfer case. I believe some have changed out the rear case and installed the manual shift linkage, but sounds easier to replace whole unit.
What I need is a transfer case control module and wiring harness, so should you do the swap let me know if you want to remove the module and wiring harness.
Thanks
C.T.
Thanks
C.T.
Thanks
C.T.
Thanks
C.T.
bigern6697
09-11-2010 08:38 PM
jem44357
01-27-2010 09:13 AM
natron343
10-05-2005 12:02 AM
