95 F150 5.0 Intake Manifold Help
Has anyone installed/ or heard good news about the edelbrock truck intake manifold? i have the k+n cold air intake kit on it. But the truck is still chocked up being the stock motor it is. will the aftermarket intake manifold add a good amount of HP to the truck? will bigger injectors be needed or just an adjustable fuel pressure regulator to tune? and will it increase my gas mileage?
Any thoughts or ideas on this or doing something else to free up power? thanks guys
95 F150 Black ext cab s/b
5.0 EFI 58,000 miles
4" Trailmaster suspension lift
K+N FIPK
Flowmaster cat back
K+N FIPK
Flowmaster cat back
Received 1,353 Likes
on
intake
yea i know it would be most beneficial on a modified motor. but even on a stock motor it has to give it some torque and give better gas mileage correct? the 5.0 truck motor is choked up. it requires alot of throttle to maintain speeds mostly on the highway and mid range. So allowing it to breathe better resulting in less throttle should increas the mileage right? What do you guys think?
Guy
05-13-2000 08:50 AM
