89 ranger 2.9 hard starting - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-02-2002, 09:44 PM
buzzedhead buzzedhead is offline
buzzedhead is starting off with a positive reputation.
I am having trouble starting my truck, but once it starts-runs good. It doesn't happen every time I start the truck-but most of the time. It turns over, but takes a few seconds to start.I've done a tuneup, fuel filter, new fuel pump. Any ideas????
Old 02-03-2002, 06:44 PM
tjohnson tjohnson is offline
tjohnson is starting off with a positive reputation.
I've heard that the ECT sensor is the most common cause of slow starting problems. It seemed to help mine start faster.
Travis
Flatheadv8
*87 ranger STX
2.9, K&N cone, Magnaflow, MSD, Flex-a-lite electric fan
31x10.50 BFG Mud terrains
15x8 Eagle 117's
6" skyjacker
Sikkens silver metallic
Ford grillgaurd, rollbar (off), tubular rear bumper all powdercoated gloss black
Delta crossbed toolbox
Clarion deck/rears, alpine fronts,
Rocford Fosgate-punch 100, punch 250,and 10"XLC
Hella FF100 fog lights
Old 02-10-2002, 01:19 PM
destiny88 destiny88 is offline
destiny88 is starting off with a positive reputation.
Old 02-12-2002, 01:24 AM
bluestang65's Avatar
bluestang65 bluestang65 is offline
bluestang65 is starting off with a positive reputation.
Where and what is the ECT sensor? What are the symptoms when they go bad? I have done EVERYTHING i can think of to fix my Bronco II and it still stalls out and wont run. It is getting plenty of fuel and would not start with either. Replaced: Fuel filter, Module, Pick up coil, Coil, Cap, Rotor, Wires, Etc.
Old 02-12-2002, 07:47 AM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
The ECT is the coolant temperature sensor. On a 2.9 it is located near the thermostat. Make sure you replace the one that has two wires, the one that has a single wire is for the gauge. The sensor have a specific resistance at a specific temperature, you can test this with an ohm meter.
Old 02-13-2002, 05:43 AM
honest_jon honest_jon is offline
honest_jon is starting off with a positive reputation.
My old ranger (89 4x4, 2.9) always started hard...and over a period of two years I replaced everything I could think of ...then finally gave up and decided to live with it. A month later I sold the truck. Good luck.
1995 F-150 XLT 4x4
300 I6
5" Superlift
33x12.50 Wild Country
Cab Visor
Flush Fiberglass bedcover
steps, etc.
Ranger starting issues hackdad7725 Ranger & B-Series 4 07-31-2014 07:13 PM
fuel issue? rdgoodnight 1994.5 - 1997 7.3L Power Stroke Diesel 1 11-30-2011 02:42 PM
Wont start when hot Dstosh 6.0L Power Stroke Diesel 5 07-27-2011 08:33 PM
Fuel filter change no start Rudiak 6.4L Power Stroke Diesel 16 01-10-2011 03:35 PM
Fuel bleed off overnight? 4wydnr 1999 - 2003 7.3L Power Stroke Diesel 11 04-29-2009 08:17 PM
Tags
1989, 29, 87, 89, ect, hard, ranger, sensor, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
