need help in prosses of hooking up boost
Look where you oil fill is. Put your hand on it then follow it straight back to the firewall. There is a hose that goes to the firewall to a box. that is your map sensor. Just put a tee in that line and that gives you your boost reading
Here's a good site: http://www.smokyvalley.com/gauge_install.htm
Also look at the dieselmanor website, under Resources, then Install Instructions. Very nice step-by-step.
Thanks
Thanks for the help. I was thrown off because I did not have a t for by boost set. Went to the auto parts store and riged up an adapter. I guess there is no way to know if it is leaking or not?? With the 60hp predator setting the most boost I can get is about 20 psi.
Thanks again..
Thanks again..
That doesn't seem right. Does your truck seem to bog down after 20psi? I think the computer will tell the truck to defuel about 22-24psi. With a chip I would think you should see higher ratings than that. Did you hose clamp or wire tie your connections? Were they barbed fitting? I'm thinking possible leakage.
I used a 3 way copper barbed fitting in line with the map senser hone. I came off the thre-way with a 2 " pig tail of the same size hose. The only fitting I had to go into my pigtail was a 3/4 male threded copper piece. I screwed in the copper piece and put a hose clamp on all my connections. Used pipe dope on my ferreur fitting. The rig may have not worked. Is there any way to test it? I guess I could take off the hose on the map sensor and pressurize it somehow and watch my boost gauge.
