LARGEST TIRES THAT CAN FIT UNDER 2001 FORD RANGER - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-16-2002, 10:54 PM
blinn79 blinn79 is offline
blinn79 is starting off with a positive reputation.
What are the largest tires that can fit on a 2001 Ford Ranger Edge??? It has 15" rims on it right now...so will 31X10.50's fit???
Old 02-17-2002, 03:34 PM
224Man 224Man is offline
224Man is starting off with a positive reputation.
I have a 2001 15" rims with 31" tires they don't rub at all. DO NOT get Mud Terrain Tires though, they cause horrible road noise and have much worse handling. I have Michellin LTX M/S and love them, if you offroad alot I would get A/Ts such as Goodyear A/Ts. Best of Luck.
Old 02-17-2002, 09:49 PM
2000RangerXL 2000RangerXL is offline
2000RangerXL is starting off with a positive reputation.
I have a weird number on the side of my tires. Can anyone clarify the diameter? It reads "P225 70R15" I know the 15 is the size of the rim and R is radial but what's the 70? My stepdad told me it's centimeters, ah screw it I'll just go measure the tire. So I'll be able to fit 31's under my truck?
Old 02-17-2002, 10:22 PM
[updated:LAST EDITED ON 17-Feb-02 AT 10:24 PM (EST)]I'm not sure if they will fit on XL's I do know 31"s will fit on 2x4 2001 Edges
For This example well say you have 235/75/R15
Standard tire sizing works like this
First number is the width of the tire in millimeters (235 mm).
Second number is the aspect ratio (its the height of the sidewall) you multiply the second number by the first to get the height of the sidewall so 235mm * 0.75= 176.25mm .
r15 is your rim diameter in inches.
F
So to find your total tire diameter you multipy your sidewall height times two since there's a sidewall on each side of the rim.
176.25mm * 2= 352.5mm
Now to convert mm to inches you DIVIDE by 25.4, conversely to convert inches to mm you MULTIPLY by 25.4.
So we take the height of both side walls and convert it to inches
352.5mm / 25.4 = 13.88 inches
add the height of BOTH sidewalls and the diameter of the rim to obtain the tire diameter 13.88 inches + 15 inches = 29 inches
The width of the tire in inches is 235 / 25.4 = 9.25 inches
So your tire sixe in inches is 29x9.5 R15
Old 02-17-2002, 10:47 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Old 05-04-2003, 12:59 AM
jcandrew jcandrew is offline
jcandrew is starting off with a positive reputation.
Angry LARGEST TIRES THAT CAN FIT UNDER 2001 FORD RANGER
I am currently running 265/75/15 tires on my 2000 Ford Ranger and love them! The tire diameter for theses works out to 30.7 inches. This actually did a few things for me. Number one it corrected my speedometer gauge which was previously reading about 5 mph to fast; and Secondly, it lowered my cruising tachometer reading from 2700 rpm at 60 mph to about 2300 rpm at 60! A third benefit of these tires are that they help smooth out the ride. I bought these tires from the local Ford dealership--all terrain tread for street use--BF Goodrich Commando XTs. I have had them on for about a week--no rubbing this far.
Old 05-05-2003, 11:06 AM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
27.5 inch tire
Quote:
Old 05-05-2003, 11:10 AM
With some minor rubbing. The Edge sits higher then your truck
Old 05-06-2003, 11:37 PM
Thumbs up LARGEST TIRES THAT CAN FIT UNDER 2001 FORD RANGER
I forgot to mention in my post above that I do have the "tow package" installed on my 2000 2X4 Ford Ranger so it does give some extra clearance under the wheel wells. I am running the following tire size: 265/75/15. Still no rubbing so far. Also see above message that I posted. The tire diameter measures 30.7 inches.
Old 07-04-2007, 01:41 AM
flyingv2000 flyingv2000 is offline
flyingv2000 is starting off with a positive reputation.
i have a 2000 ford ranger. ext cab. its 2wd, a v6 3.0 liter. what are the largest possible tires i can fit on without rubbing? i would want a fab tech spindle lift but i'm going to save some money. i would like all terrain tires do any of you know of good tires? i have currently 235 75 R15.
thanks
Old 07-04-2007, 01:42 AM
2000 ford ranger
thanks
Old 07-04-2007, 06:49 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
4x4's and edge models will easily fit a 31/10.50.
Old 07-04-2007, 12:10 PM
Bigtony4 Bigtony4 is offline
Bigtony4 is starting off with a positive reputation.
I have 32 inch tires on an 04 4x4 with 16 inch wheels. I do not have any rubbing.
Old 07-04-2007, 01:10 PM
so do you think its possible to fit 30S on my 2000 ford ranger
Old 07-04-2007, 11:09 PM
You should fit 30 inch tires with no problem.
Largest tire fit Rudiak 1999 to 2016 Super Duty 3 09-03-2014 01:52 PM
2002 ford f350 6 " lift to be installed what's largest tires? superglide04 1999 to 2016 Super Duty 4 07-30-2013 01:52 PM
Largest tire on stock rim??? balderman 1999 - 2003 7.3L Power Stroke Diesel 21 04-05-2009 09:04 PM
LARGEST TIRES THAT CAN FIT UNDER A 2001 FORD RANGER blinn79 Brakes, Steering, Suspension, Tires, & Wheels 1 02-16-2002 10:55 PM
Largest Size Tires for F350 wgm114 1999 to 2016 Super Duty 3 01-21-2002 08:26 PM
Tags
01, 1986, 2000, 2001, 4x4, bigger, biggest, fit, ford, largest, put, ranger, rims, size, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
