Pistons and rods
Pistons and rods
im wondering what style pistons every one uses on there 351w. Im looking at the TRW flattops 1.772c/h p/n h336p but they have the dished pistons L2378F im not sure what to go with I use flattops on my FE builds but im not sure about the windsors. Also what is the rod length and deck height for a 92 351w? Im trying to figure out my CR for my build.
Rods are 5.956 and deck height is 9.5.
With the 1.772 c/h piston that put them about .022 in the hole.
I can't remember what the combustion chamber is on the E7's (anybody?).
Assuming -4cc valve relief's and 62cc chambers, stock bore with a .041 head gasket (stock replacement) they put you about 10.07:1 with a .063 quench. While the quench is typical for stock, this won't work with the compression with pump gas without a good sized cam and VERY conservitive timing curve.
What is the dish volume on the L2378F?
1996pwrstrk
04-19-2013 07:34 AM
7636074460
05-07-2012 08:58 AM
grif95
03-22-2003 03:30 PM
