Pennzoil 15/40 - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Pennzoil 15/40
Old 11-23-2004, 12:04 AM
grave grave is offline
grave is starting off with a positive reputation.
Pennzoil 15/40
I am purchasing 250 6.0 next month. I always use pennzoil in my f150 5/30. what do you think of pennzoil 15/40 for this new truck. Would this oil be as good as rotella or motorcraft. please the whole truth and nothing but the truth.Thankyou !
Old 11-23-2004, 01:01 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
It would probably work ok, but it's not what I would use. I'd use Mystik, Rotella, or Delvac. In that order of preference.
Old 11-23-2004, 01:07 PM
tomf52 tomf52 is offline
tomf52 is starting off with a positive reputation.
Use what the owner's ,manual calls for , weight wise that is. The engineers know a hell of a a lot more than we do. I have always followed the book and have gotten incredible(400,000 mi on one vehicle) life out of my trucks.
Old 11-24-2004, 02:14 PM
Momudder720's Avatar
Momudder720 Momudder720 is offline
Momudder720 is starting off with a positive reputation.
Rotella 15-40. I've always heard that Pennzoil is bad for the engine, but EVERYONE has heard bunk like that before.
If Rotella is good enough for the OTR million-mile trucks, is it not good enough for you?
Old 11-24-2004, 06:02 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
I've used it before I switched to Mobil 1 Delvac 5-40. It is a very good oil. No worries about it either, it's rated CG-4 and all the others (I can't remember them all right now). It's good enough for the big rigs so it will be more than enough for your 6.0
Synthetic is much better though.
Old 11-24-2004, 08:18 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
Quote:
This appears to be a fairly new modular OHC motor. A 40 weight should not be necessary unless the engine is worn enough that the oil pressure is below spec. I would run a 30 weight in it, probably Valvoline Maxlife. But if you want a thicker 30 weight and a heavy duty motor oil additive package, Citgo Ultralife ("high mileage") 10w30 is in the upper end of the 30 weight range and has hefty doses of zinc and phosphorus.
Old 11-24-2004, 10:37 PM
Saurian's Avatar
Saurian Saurian is offline
Saurian has a good reputation on FTE.Saurian has a good reputation on FTE.
Tallpall...the 6.0 is the Diesel 365 from International isn't it?
Didn't Ford send out a TSB on running the new 365's on 10W30 diesel or something? Just asking.
I'd stick with Rotella (Dino for break in, Synthetic after 10,000 miles) or Delvac. I'm a HUGE Motorcraft fan...but those two diesel oils cannot be beaten.
Old 11-24-2004, 11:09 PM
TallPaul's Avatar
Oops. I forgot about diesels. I was thinking it had the V10 gasser. I really don't know what they run in the diesels.
Old 11-24-2004, 11:16 PM
15w40 is the normal viscosity specified for most diesels. I THINK they say in winter you're supposed to use a diesel rated 10w30 on the PSD's because of some fuel delivery issue caused because the injectors use engine oil in their normal operations, and 15w40 becomes too thick.
switching between reg and syn oil dhag911 6.0L Power Stroke Diesel 36 10-31-2015 03:47 PM
New Pennzoil Ultra Gage2502 Oil & Lubrication 9 07-23-2010 03:49 PM
Shell rotella owned by pennzoil??? 429law 1999 - 2003 7.3L Power Stroke Diesel 9 10-02-2009 07:13 PM
everyone says pennzoil sucks poopey Oil & Lubrication 11 10-07-2002 08:59 PM
Castrol's new 15-40 mikemc Oil & Lubrication 3 06-12-2002 07:25 PM
Tags
15, 1540, 15w40, 1992, 40, 530, ct, gas, jetta, motor, oil, pennzoil, pennzoils, synthetic, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
