How it works AWD System
Originally Posted by Marth
I have a 1997 Ford Explorer V8 5.0 AWD and i would like to kwon how AWD system works.
The 4 wheels must turn at same time or like 4x2.
Please melp me...
Please melp me...
Make sense?
awd
Actually the 5.0 awd is in 4 wheel drive all the time. When you go around a corner the viscious clutch in the transfer case allows slip. This viscious clutch setup puts about 35% power to the front wheels and 65% to the rear tires.
The setup that stunod2002 is referring to was in the 4.0 engine setups.
Why would they do that anyway?
Perhaps my only complaint against putting the 5.0 into Explorers was that Ford decided that they wouldn't put a true 4WD system in with it. 5.0 Explorers either came 2WD or AWD. The idea behind an AWD system:
1) All four wheels are powered all the time. As mentioned, the t-case consists of viscous clutches. Under normal conditions, there is a 35:65 power split front to rear. The clutches are set up to allow differentiation during cornering and such.
2) When the computer detects wheel spin, it can adjust the power split at the transfer case, up to (I believe) 97% to either front or rear.
3) The AWD system operates without any input from the operator. There isn't a selectable 2WD mode, the transfer case isn't lockable like a part time 4WD system, and there isn't a low range. This is the part I would miss.
I do miss the low range (and the real lock up option--I think the viscous limited slip gets overwhelmed in real high-torque situations), but I love the way the AWD handles in snow and muddy roads. For the 2004 Explorer I opted for the 4X4 with advance trac. I'll do an offroad comparison-when my wife is done with it in a few years!
So, does that make my father in-laws truck an oddball? It's got the SOHC 4.0 with the AWD, but the selector also has 4lo and 4hi....just no 2wd. Is that different than the 5.0 AWD system, or the same one? It's a 97 XLT, but has (I think) every option you cold get except for the Eddie Bauer ground effects.
Beausterling: I always thought there was an electrical element to the AWD system, just like the electrical element in the 4Auto mode in the V6 t-cases. I could be wrong on that.
The AWD in the earlier explorers with the 5.0 is entirely mechanical. It's basicly like a limited slip clutch. Power is mostly to the rear wheels. The viscous coupler goes to the front diff. It has a serious of clutches, and fluid that gets thicker as if gets warmer. When there is more slip, there is more friction (ie more heat), which makes the clutches lockup. I had the same system in an 86 VW Van with AWD, been around forever
