1975 F 150 Lights
1975 F 150 Lights
New to the list. Just purchased a 1975 F150 from Iowa, originally from Fairmont MN with 71 k ? on it. Has some minor rust starting but nothing to serious for a 30 year old truck. The voltage regulator was bad and before I could replace it I ended up loosing both high and low beam headlights. Have not been able to locate the fuse, tried both the fuse box and looked for an in line fuse, no luck.
Any suggestions? Thanks in advance.
Jim
Jim
Sounds like a nice truck.
Do all the other electronics work - wipers, park lights, radio, heater fan?
Usually when the headlights go out (but park lights still work) the problem is either the headlight switch or the dimmer switch on the floor - more often its the dimmer switch...
Dimmer switch will run about $15 and headlight switch will run about $30.
Marty
Marty
eaglesguy1981j
13
06-03-2013 10:33 PM
IowaHighBoy
36
03-08-2009 09:27 AM
