352 police interceptor rebuild kit
Old 11-21-2004, 08:03 PM
250-1968_campspecial's Avatar
250-1968_campspecial is offline
where can i find a rebuild kit and a four barrel carb mount maybe even dually 4 barrels
Old 11-21-2004, 08:23 PM
sevenL4's Avatar
sevenL4
sevenL4 is offline
Northern Auto Parts
http://www.naparts.com
Request a catalog. I've built several engines using their parts.
Old 11-21-2004, 08:31 PM
they dont have 352 engine kits but i went ahead and got a catalog
Old 11-22-2004, 08:28 AM
sevenL4's Avatar
sevenL4
sevenL4 is offline
I thought they might not have a kit listed. Did you ask if they would put one together for you? I think the 352 probably lost its popularity after the 390 arrived.
Unless you have a definite need to rebuild the 352, I suggest you look for a 390. They are plentiful and one built to 68/70 specs can be a real workhorse. My machinist likes them because they usually clean up with only minor machining on the first rebuild.
I had one that had 168,000 miles on it. Got it out of a station wagon. The crank showed no significant wear so it was polished only. The cylinders would have cleaned up at .010 but I had it bored .030 over because the .030 pistons were cheaper.
I'll grant you that was a fluke but two others only needed .010 on the crank and .030 over bore.
BTW, Edelbrock makes a 4 bbl intake for the FE engines. I've seen them on Ebay and at swap meets for less then $100.
Bronc1
1978 - 1996 Big Bronco
09-23-2015 11:33 PM
bluesnake2006
35
12-02-2013 08:17 PM
Birdman_7137
17
07-18-2013 10:56 AM
SmallBlockV8
01-20-2010 10:43 PM
ford4604bbl
03-27-2006 07:23 PM
Quick Reply: 352 police interceptor rebuild kit
