SOHC V6 firing order & coil connection? - Ford Truck Enthusiasts Forums
Old 11-21-2004, 08:49 PM
bk_89ix bk_89ix is offline
bk_89ix is starting off with a positive reputation.
Can someone please confirm for me the proper connection order of the
spark plug wires to the coil pack on a '97 SOHC V6? I'm having running
trouble after changing out the upper/lower intake gaskets. Forgot to
mention in an earlier post that at the same time I also changed four of
the six spark plugs and wires.....one at a time I thought, but I'd love
for the explanation to be a simple misrouted wire!!
Bob
Old 11-22-2004, 12:01 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Old 11-22-2004, 02:04 AM
you 'da man!
Exactly (!) what I was looking for to confirm routing.
But dang, that's the way I've got them hooked up....my idle issue must be somewhere else...I'm thinking I probably should not have installed the intake gaskets dry...now the fun begins...
Old 11-22-2004, 09:14 AM
Racerguy's Avatar
The intake gaskets are supposed to be installed dry on these.
It's sometimes a bit of a pain to keep the o-rings in place though when installing the intake. You have to be very careful.
On the lower intake there is a R and L on it. It looks like it would work either way but I've never tried installing one backwards. It might be something to check.
Old 11-22-2004, 12:03 PM
Let's make sure we're talking about the same motor: '97 SOHC 4L V6. The lower intake gaskets (light-blue O-rings) came sealed in bag of six from the dealer. I looked them over carefully and they looked symmetrical. The upper intake gaskets (black ovals) came sealed in a bag of two...didn't see any R/L designation, but again they LOOKED identical. Or are you referring to the black plastic intake itself? Now that's an interesting point....is the R/L marking somewhere where I could see it after installation? Any other way to confirm proper intake orienation??
Bob
Old 11-22-2004, 01:00 PM
Racerguy's Avatar
Yes it's the lower intake that has an R and L on the side of it. I don't know if you can see that when it's on the engine. Like I said I'm not sure if it makes a difference or not.
Old 11-23-2004, 11:50 PM
Good news! After going through things one more time, including checking continuity of the new ignition wires and using the "correct" PCV valve and a new intake bellows for good measure, she's running properly. Hard to say what the real issue was, but it seems to have been resolved and therefore the intake is apparently bolted up properly. I looked real hard for R/L markings on the installed part, but I was unable to find them. Thanks for your help!
Bob
Old 11-24-2004, 01:04 AM
Racerguy's Avatar
Good to hear that you got it fixed
crossed wires rob8210 Explorer, Sport Trac, Mountaineer & Aviator 3 04-27-2014 08:15 PM
How do you pull the spark plug on the Triton 5.4 V8? Johnny Bravo 45 1999 to 2016 Super Duty 21 12-29-2012 09:38 PM
Hot Coil 53redford 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-13-2007 05:51 PM
OD making shuddering vibration robodeb Explorer, Sport Trac, Mountaineer & Aviator 5 07-09-2003 07:19 PM
Igniton timeing and spark plug gap bigred78 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 09-21-2002 01:22 AM
Tags
150, 1999, 2001, 42, 97, coil, escape, explorer, fireing, firing, ford, order, pack, soch, sohc, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
