Keyless Entry Fuse Blowing - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-15-2002, 05:02 PM
Poggin Poggin is offline
Poggin is starting off with a positive reputation.
As to a followup on my post I made yesterday, I took the adive I was given...thansk for that!
But now, everytime I put a fuse into the number 20 module, the fuse instantly blows when I turn the key to the on position.
I am fearing I have some kind of short in my wiring but I am not sure.
If anyone has any info on what this actually is, or could be, I would appreciate it greatly.
Thanks all!
Old 03-15-2002, 10:36 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
The best way to diagnosis this is with a scanner but if you have a wiring diagram and a meter you can do some testing. I sounds like you might have a short in the wire from the fuse box to the RAP module or a short to power from the RAP to the relay(s). Is this just one door or both?
Old 03-16-2002, 12:03 AM
bubbernator bubbernator is offline
bubbernator is starting off with a positive reputation.
NEED HELP!!! 97 Expo brake fuse geminijay313 Expedition & Navigator 5 05-23-2014 12:45 PM
NEED HELP 97 Expo brake fuse geminijay313 Large Truck 0 05-22-2014 07:51 PM
Engine control fuse blowing ralleyclimber 1999 - 2003 7.3L Power Stroke Diesel 8 04-28-2014 12:30 PM
97 F250 Overdrive switch blows fuse kxmurray 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-14-2007 01:31 AM
Cigarette lighter not working/blowing fuses kms910 Expedition & Navigator 4 05-27-2004 03:56 AM
Tags
entry, f150, ford, fuse, keyless
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
