Clutch question
Clutch question
I've been having some trouble with the clutch in my '94 Ranger 4x4 with the 4.0 5-speed. The main problem is difficulty engaging gears when stopped. Sometimes it acts pretty normal and other times it will barely go into gear at all. It seems like the clutch isn't releasing completely. The strange thing is the inconsistency. It seems to behave better when the outdoor temperature is fairly cold, but that isn't consistent either. Does any of this sound familiar? Could it just need bled? (Sounds like piles of fun from what I've been reading) The truck has just over 100k on it. I have no idea when or if the clutch has been changed. I've also noticed that there is quite a bit of free play at the top of the travel on the pedal. Is that normal?
Thanks for any help or suggestions.
Ray
Ray
