7.3 vacuum pump pulley
Kinda...Go to autozone or your local parts supplier and get a power steering pulley puller, then grind a bevel on the outside of the jaws next to the pulley so it clears the concave bevel of the vacuum pump pulley. This is easy to do, the puller is about 12 dollars. The rest of the operation is able to be done without modifications to the puller.
Your only other option is to go to a Ford dealer and have them do it with the Rotunda tool made for the job.
Comes from living in the mountains, ya have to learn to make things work from a limited supply of materials and tools. Last time mine went out it was Saturday afternoon, no shops open till Monday morning. Truck had to run with brakes Sunday.
I took a 15 dollar gamble that I could make the power steering puller work so I could change my pump. It worked well, has changed several since then, so do not loose it.
When you grind it down just be carefull that you do not get the shoulder to thin as it may break. Some of those pulleys are a little tough to get off.
mxer0022
09-13-2016 09:58 PM
Marky48170
07-29-2012 09:00 AM
