1960 F-100 steering conversion
on
Originally Posted by exidenick
Thanks, Do you know the specifics, as to what Year make ?
Vern
57-60 steering conversion
No Limit Engineering makes an off-the-shelf kit for this. $286.00 The hard part is finding the toyota gearbox in a junkyard. http://www.nolimit.net/Products/PowerSteer.htm
good luck/Mike
good luck/Mike
The Toyota box comes from a 1979-1985 and it should be from a 4X4. CPP also offers a bushing and collar to use the stock column and mate to the Toyota box. You can check it out at http://www.classicperform.com/produc...ord/F100CS.htm
These kits/parts are designed for 1953-56 but may work for other years.
Kevin
Kevin
for ANY used parts:
www.car-parts.com
thats how I got mine, 80-84 Toyota 4x4 pickup It's a short box ~ 9.5" long and mounts with 2 bolts on each side of the sector shaft. You can get a bolt on or weld on installation kit from Mid Fifties including the correctly splined arm. They also offer the rebuilt box for ~ the same price as parts houses and you'll be sure you're getting the right one. Check em out on line, nice people.
www.car-parts.com
Maryrylee
15
02-28-2019 11:16 PM
halltm
11-15-2017 05:59 PM
mdavis1020
22
05-17-2013 08:42 AM
jls1965
03-01-2012 12:23 PM
65fordman
07-17-2011 07:19 AM
