1996 Ford Ranger XLT, 3.0 V6 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-22-2002, 07:06 PM
bizjettech bizjettech is offline
bizjettech is starting off with a positive reputation.
My Ranger has a problem with warm temp starts. In the morning when it's cool it starts no prob. After work I go to start it and it refuses me. It turns over no prob and attempts to kick in. Sounds like it burns up the vapor in the lines and that's it. There's no pressure at the test port. I have no desire to dig into the tank just yet to rip out the pump (it's almost full). Anyone have any ideas as to why I'm not getting the fuel I need when it's time to go home? I work on Corporate Jets and know something about environmental factors like temperature extremes, but, since I know little about the interworkings of todays computerized vehicles, I am in much need of help. Oh ya! This is a great site! Big Thanks to those who have made it what it is!
Old 03-22-2002, 10:37 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Since you know that you don't have fuel pressure when it won't start it can be either a fuel pump problem or electrical problem. Listen the next time it won't start to see if you hear the pump run when you turn the key to on. If you don't hear it check for power to the pump, you might want to have someone help you since the pump times out in a few seconds. If you don't have power, check it out at the inertia switch, also look at the relays. If the pump does run, but still no pressure look at the filter. If you have to do the pump it's easier to pull the bed rather than dropping the tank.
Old 03-22-2002, 10:44 PM
Ken00's Avatar
97 ranger wont start after sitting a month joeKyTN Ranger & B-Series 0 05-19-2012 11:28 PM
Def stuck at this point the78ranger 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-17-2011 08:35 PM
1997 ford ranger gem guitar48 Electrical Systems/Wiring 2 12-22-2008 08:11 AM
tach is acting Spastic! jerclark Ranger & B-Series 2 08-18-2006 05:19 PM
tranny problems big truck driver 1987 - 1996 F150 & Larger F-Series Trucks 1 09-15-2003 06:27 AM
Tags
1996, 30, electrical, ford, fuel, oil, pressure, problems, pump, ranger, reviews, start1996, truck, v6, xl, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
