problem cycling
Old 11-19-2004, 08:36 AM
shendoa's Avatar
shendoa
shendoa is offline
problem cycling
Last night i drove about 50 miles, then i put emergency brake on, went out to listen to the engine good. then i heard something weard i think i never heard before, or it never cught me attention, the engine was cycling, like rinning at 800 rpm then 700 rpm then back to 800 rpm. cycle is like every 2 to 3 seconds and last forever. Is this normal or is something going bad, anyone else hear this, it idles like an old greyhound buss.
Old 11-19-2004, 08:51 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
I see you live in N. Maine. Was it really cold out? I am thinking that it's just your fast idle cycling on and off slightly. I live in Seattle where a freeze is very rare, but the engine will fast idle with differing degrees of intensity depending on temperature. Colder=faster. Warmer=slower.
Old 11-19-2004, 08:53 AM
shendoa's Avatar
shendoa
shendoa is offline
no it was 56 degrees yesturday when it was doing it. and the engine was up to temp after 50 miles.
Old 11-19-2004, 08:55 AM
shendoa's Avatar
shendoa
shendoa is offline
it was cycling everytwo second maybe 1 second had to listen good th hear it.
Old 11-19-2004, 08:56 AM
Kwikkordead
Well then we are back to looking at things like time for an oil change, fuel filter, possibly a failing temp senser.
Old 11-19-2004, 09:00 AM
shendoa's Avatar
shendoa
shendoa is offline
where is the temp sensor? everything else is new
Old 11-19-2004, 09:10 AM
shendoa's Avatar
shendoa
shendoa is offline
every time it cycles i hear a click like a lifter just before it changes cycling, like the cam is hitting the fuel pump, and the click is cear the fuel pume, the click has heen their ever since i had the truck 2 years, just thought it was fuel pump and normal?
click-cycle click cycle click-cycle click cycle click-cycle click cycle click-cycle click cycle every 1 or 2 seconds, maybe they all do that?? about 50 rpm diferent, what do you think??? only after it it warmed up totaly, if cold it don't do that.
Kwikkordead
I am not sure. I was thinking that your intake air temperature sensor might be giving you trouble, sending a IAT signal that was far colder than reality.
Anyone care to chime in here? I am mainly guessing at this point.
Old 11-19-2004, 09:18 AM
shendoa's Avatar
shendoa
shendoa is offline
I have a tymar intake, the temp sensor is just tied up in mid air. did not know what else to do with it. it don't move it is secure
Old 11-19-2004, 09:23 AM
shendoa's Avatar
shendoa
shendoa is offline
is a psd suppose to idle at a steady rpm not even 20 rpm different, like a finely tuned gasser???after warmed up/ next time you drive yours,after totaly warmed up open hood and listen to you engine, real good and please tell me if you hear a fine tick and cycle, listen good it hard to hear.
Old 11-19-2004, 09:26 AM
shendoa's Avatar
shendoa
shendoa is offline
I have been a auto mechanic all my life, i am now 63 and retiered, just learning about diesels,
Old 11-19-2004, 10:15 AM
doc526's Avatar
doc526
doc526 is offline
Just for thought, look at the a/c compressor. Sounds like the engine is uping the idle to compensate for the compressor kicking on and idles down when the compressor disengages.
DEAN
Old 11-19-2004, 10:47 AM
shendoa's Avatar
shendoa
shendoa is offline
no ac not comming on the click is not that loud
Old 11-19-2004, 11:43 AM
RynL88's Avatar
RynL88
RynL88 is offline
just to make you feel better mine does the exact same thing except I've noticed no click-will listen next time i think about it, mine only does it when its warm too, idles beautifuly cold. I have lots of miles so I am just assuming that its a normal wear and tear problem. I've seen a post about cleaning the screen in the fuel filter housing and that cleared up the problem, next time I change my filter I will give that a shot, I'm not too worried though.
Old 11-19-2004, 09:54 PM
Kwikkordead
Do you have a fuel pressure guage left over from pre-retirement? It might be helpful to see what's going on there with that click noise coming from the pump. Possibly the fuel pressure is spiking or something.
Quick Reply: problem cycling
