Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-19-2004, 03:01 AM
thesprocket26's Avatar
thesprocket26 thesprocket26 is offline
thesprocket26 is gaining momentum as a positive member of FTE.
460 mates to np435?
Could I mate a 460 to a np435 4speed? Its in my 67 f100. What is needed for this combination? I thought some early 80's fords had manual trannys on 460's. Is that the same tranny? Thanks ya'lls.
  #2 (permalink)
Old 11-19-2004, 09:43 AM
stangboy_82 stangboy_82 is offline
stangboy_82 is starting off with a positive reputation.
yes it's perfectly feasable (however you spell that word I dunno) I put an np435 in my 86 f250 as far as I know any 4 speed tranny bellhousing that bolts up to the 460 will work(I'm pretty sure I used a bellhousing from a t19 or t18) on it just make sure that it is old enough that it is from a truck that has a manual clutch instead of a hydraulic that was my first problem was trying to use a bell from a truck with a manual operated clutch in my truck. you could get a bellhousing from a ford truck I believe 83 or earlier, you won't find an 80-83 truck with 460 but 400/351M bellhousing's will work also. good luck and have fun with it
  #3 (permalink)
Old 11-19-2004, 10:15 PM
Kenworth Kenworth is offline
Kenworth is starting off with a positive reputation.
You will need a 351/400 Bellhousing and a 390 flywheel drilled for a 11" clutch then you can put a 4spd behind a 460. I did it this way it worked fairly well this combination was figured out by a junk yard. I did the conversion over 6 years ago so I don't remember all the details. It sure made a difference in power the 460 I had was in a 77 1 ton dually that I hauled heavy loads on. I wanted a 4spd so I could use the gears to help decend hills.
Ohya I just rembered I did have to make a spacer plate that went bettween the bellhousing and the transmission the crank snout on the 460 with the thicker flywheel and the shallow depth on the bellhousing the input shaft on the transmission is too long.
  #4 (permalink)
Old 11-22-2004, 10:14 AM
just my opinion I'm not trying to bend noses :-P but I wouldn't really go with the 390 flywheel unless you make absolutely sure that you're getting one that is balanced the same as your 460. I'm not saying it won't work I just wouldn't want to put an incorectly balanced flywheel on my motor and have it not run right after doing all that work.
As far as that go's you can buy one new and it's not all that expensive pioneer makes them you can get it from an autozone or o'reilly's (if either place tells you otherwise wave the bs flag and find a partsman that's not slow in the head and actually cares about finding parts for his customers) and most likely any other parts store that carries pioneer products (most do)
as far as the spacer I did not run into this problem with the np435. I called one of my buddies that is back in the states and had him compare some back at home so between an 85 f350 460 bellhousing and 80 351M/400 bellhousing
he was unable to find any measurement differences besides the fact that the 351M/400 bellhousing used a manual clutch instead of hydraulic
good luck
  #5 (permalink)
Old 11-22-2004, 11:22 AM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
I believe the 390 is a zero balance flywheel, the 410 and 428 was externally balanced.
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #6 (permalink)
Old 11-22-2004, 10:23 PM
jesse460 jesse460 is offline
jesse460 is starting off with a positive reputation.
Mike G is right a 360 flywheel will also work. 460 are neutrally balanced as well.
  #7 (permalink)
Old 11-23-2004, 01:44 AM
Ok guys. So what is the difference with externally ballanced and zero balanced? I am just learning about transmissiona and the related parts.
  #8 (permalink)
Old 11-29-2004, 12:02 AM
daerhldgs2 daerhldgs2 is offline
daerhldgs2 is starting off with a positive reputation.
the 460 was zero balance until 77 and then they went to a imbalance so it matters which year 460 you have. They did use 460s with 4spd manual trans in the late 80s and early 90s so the right flywheel is available if it's a newer 460.Until and I believe incl. 77 the 460s were all internally balanced hence the zero balance on the harmonic bal. and the flywheel, after that they balanced the engine externally with the flywheel and harmonic bal.
  #9 (permalink)
Old 12-07-2004, 06:17 PM
motorhead_83 motorhead_83 is offline
motorhead_83 is starting off with a positive reputation.
The combo I used was a 390 Flywheel with my '69 460 and 351m bell housing behind an NP435. Instead of the spacer plate between the engine and bellhousing, I turned the 460 Pilot bushing down on a lathe until it fit into the deepest step in the back of the crankshaft. I fitted it up and made sure the output shaft of the trans wasn't anywhere neare contacting the back of the crank. Works awesome. I was told that a 302 pilot bushing was the correct size if you don't have access to a lathe.
Dan
__________________
Dan Olson
1979 F150 4x4, 9" of lift, 4spd, built 400, 40" swampers and big gnarly chrome stacks!
  #10 (permalink)
Old 11-06-2009, 09:02 AM
FLCRACKER561 FLCRACKER561 is offline
FLCRACKER561 is starting off with a positive reputation.
i got a 78 f250 with a 460 and a np435 and ive been havin problems with the starters. the teeth on the starters would get chewer up after a few cranks and thoes were fron autozone so i went to bennett thinkin they had better starters and they did so it chewed up the flywheel so i got a feelin that its not the right flywheel. what flywheel do yall think i should use? and dose the number of teeth make a differncew is so how many should i have on the right one?
  #11 (permalink)
Old 11-06-2009, 10:18 AM
The nose on the starter is different for a automatic than a standard , I think if m memory is correct the auto one is shorter and as such the teeth don't engage fully and can cause the problems you describe, check this out as to which is longer shorter as I may be wrong that the auto one is shorter.
  #12 (permalink)
Old 11-06-2009, 10:48 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
390's used an 11 1/2" clutch on a 12 7/8" bolt circle. The same flywheel was used in all 1965/76 390's.
C5AZ6375L .. 390 Flywheel / Marked: C5AE-6380-K
352/360's used an 11" clutch on a 12 3/8" bolt circle. The same flywheel was used in all 1965/67 352's and 1968/76 360's.
C5AZ6375K .. 352/360 Flywheel / Marked: C5AE-6380-J.
1983 was the first year Ford offered a M/T with a 460 engine, and the first year Ford offered a 460 with 4WD.
daerhldgs2: That info you posted about the 460 changeover is in-correct!
The 460 engine changed mid-year 1979 not in 1977.
C
1971/78 and some 1979 460's with the D1VE block casting number prefix do not use a weighted spacer.
Some 1979 460's with the D9TE block casting number prefix USE a weighted spacer.
Since this was a "running change" that occured midyear 1979, there is no before/from a certain production date or serial number.
D9TE blocks use a different harmonic balancer and flywheel than the DIVE blocks.
Your 460 starter info is also in-correct!
E1TZ11002C .. 460 Starter (Motorcraft SA717A)
Fits: 1968/97 460 with A/T or M/T.
stangboy_82: 1980/82 F250/350's were not available with 460 engnes, but Econolines were.
The 460 was re-introduced in F250/350's in 1983.
No 460's in 1977 and later F100's / No 460's in 1980 and later F150's / No 460's in passenger cars after 1978.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #13 (permalink)
Old 11-06-2009, 12:03 PM
Ford Parts Guru
Quote:
Originally Posted by FLCRACKER561 View Post
i got a 78 f250 with a 460 and a np435 and ive been having problems with the starters.
the teeth on the starters would get chewed up after a few cranks and thoes were from autozone so i went to bennett thinkin they had better starters and they did so it chewed up the flywheel.
So i got a feelin that its not the right flywheel. what flywheel do yall think i should use? and does the number of teeth make a difference is so how many should i have on the right one?
Welcome to FTE
Since Ford did not offer a manual transmission with a 460 engine until 1983, what flywheel does your truck have?
What starter are you using? One from a 460, or from something else?
__________________
  #14 (permalink)
Old 11-06-2009, 03:06 PM
im not to sure what flywheel it is ive measured it in it was 12 inches and the cluch they had on it was 11 inch and the starter is from bennett for a 1978 460 the guy there showed me n a book he had that there is a differnce n m/t and a/t starter ive trhed em bothe and now i also need a flywheel
  #15 (permalink)
Old 11-06-2009, 03:47 PM
Ford Parts Guru
the guy there showed me In a book he had that there is a difference In m/t and a/t starters. That's CACA del TORO!
The FORD truck and car parts catalogs list one part number for a 460 starter: E1TZ11002C
There is no difference if it's an A/T or M/T.
__________________
Tags
460 , balanced , bell , bellhousing , bellhousings , bolt , bolts , engines , externally , flywheel , ford , house , np435 , performance , tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
