Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-18-2004, 05:29 PM
Jrock909 Jrock909 is offline
Garage is empty, add now
Jrock909 is starting off with a positive reputation.
Symptoms of a bad ECM computer
What are the symptoms of a bad ecm computer? Could a symptom be a hot restart that the motor just cranks over and over but doesn't restart right away after the first start up of the day?
  #2 (permalink)
Old 11-18-2004, 05:46 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The first computer I used for my MAF swap did this. It would start ok cold, but if I drove it any and shut it off, it would not restart for a while afterwards. I checked and tested everything that I could though, I didn't just go buy a computer because I thought it was bad. I also couldn't get any diagnostic codes out of it. It could possibly be a bad TFI module as well, but unless it cuts off while running, I would doubt that it is the TFI..
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #3 (permalink)
Old 11-18-2004, 05:51 PM
The tfi module has been replaced, but I figured it wouldn't solve my problem at all....
  #4 (permalink)
Old 11-18-2004, 06:04 PM
EPNCSU2006's Avatar
Can you get any codes out of it?
__________________
Eric
  #5 (permalink)
Old 11-18-2004, 06:14 PM
sure can't, have replaced alot of components too, it's a glitchy problem
  #6 (permalink)
Old 11-19-2004, 12:30 AM
EPNCSU2006's Avatar
I would start to suspect the ECM if you can't get any codes. There are a couple of places that will test it, and if it's bad will rebuild it. I don't have the links on my computer at school, but I think I still have them at home. I'll check this weekend.
__________________
Eric
  #7 (permalink)
Old 11-21-2004, 02:25 PM
russt russt is offline
russt is starting off with a positive reputation.
could be the guts inside the distributor - but if your ecm wont throw codes even if you disconnect something to force it to then it's probably on the fritz.
Tags
150, 1987, 96, bad, computer, ecm, f150, ford, located, problems, signs, symptom, symptoms, test, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
