pressure release sound from under drivers side
I have a new 04 F350 with only 2300 miles on it. Every once in awhile, i will get a sound coming from under the driver side of the vehicle engine compartment that sounds like back pressure being released. It happens when i am up around 2000 or more rpms and let off of the accelerator. I am gonna take the truck into the shop the first of next week just to get it checked but thought i would ask here first. It only happens when i am above 2000 rpms though. Any input is greatful thanks guys
Speaking of physics, lets take a look:
Energy = 1/2 x Mass x Velocity^2
With mass in slugs and velocity in feet per second.
Lets compare an Expedition weighing 8000 pounds traveling at 70 MPH to a 180 grain bullet traveling at 2500 feet per second.
Engergy of the Expedition.....1,310,430 ft-lbs
Energy of sniper Bullet...............2,498 ft-lbs
Or the expedition has 525 times the energy of a sniper bullet
Now to calculate the force each "projectile" has on impact we need to use the following formula:
F = MV/T
If the X stops in 1/2 second upon impact and the bullet stops in 0.0005 seconds upon impact (assuming 12 inches of penetration into a "medium") we have:
Force of the X........25,528 pounds
Force of bullet........ 3,996 pounds
Or the X imparts 6.39 more force upon impact than a bullet would.
Ain't physics grand?
F = MV/T
Originally Posted by newnamlawn
ok thanks guys, this makes me feel better. I swithced over from a duramax so i am still getting use the the sounds of the truck. Tnanks for the help again
Jeff
cause after having 8 new injectors at 26k and never getting fuelmilage over 12 mpg again loaded or unloaded, i finally got ****ed off. Chevy had my truck for almost 2 weeks doing injectors, and after i get new ones i still have a loss of power and bad milage, so i dupmed it and got something i don;t have to worry about as much. The ford is alot stronger in my opinion. I pull a 7 ton trailer and it does great.
Use of symbols or characters to mask profanity and expletives is prohibited and undermines the spirit of these guidelines.
This is NOT allowed in THIS forum, "*****" or "@ss" are not allowed either...
Your support is appreciated
Thanks
cause after having 8 new injectors at 26k and never getting fuelmilage over 12 mpg again loaded or unloaded, i finally got ****ed off. Chevy had my truck for almost 2 weeks doing injectors.
Originally Posted by SBV45
That is boost being released. If you accelerate quickly and quickly back off, the boost escapes. No, it doesn't have a waste gate. Subsequently you get that noise. It is normal for this system. It should be a wapapapa sound.
