Anybody Have C7ae-a Heads? Good Or Bad? 390 Or 428?
Old 11-17-2004, 11:12 PM
76greenmachine's Avatar
76greenmachine
76greenmachine is offline
Smile Anybody Have C7ae-a Heads? Good Or Bad? 390 Or 428?
IF ANYONE OWNES A PAIR OF THESE HEADS, PLEASE TELL ME WHAT YOUR OPINION IS. I WOULD BUY NEW DIFFERENT PAIR OR KEEP THESE, BUT NOT SURE. LOOKING FOR ATLEAST 425+ HP FROM 1966 MERCURY 390 FOR MY 76 F-250 4x4. THANKS!!!!!
Old 11-18-2004, 08:36 AM
debestuss's Avatar
debestuss
debestuss is offline
I have one. You have to get more than heads/head work to get 425+ hp but it can be done with these heads.
Oh, and Dude, take the "caps lock" off. Nobody likes to be yelled at.
Old 11-18-2004, 11:36 AM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
I have a set of C7AE-A's that I ported and polished the chambers. Look in my gallery. However, they're on my 390 that I put in the truck yesterday and they're not for sale.
You can get 425hp, but as was said, it'll be part of a total engine performance build, not just heads.
Old 11-19-2004, 06:59 AM
averagef250's Avatar
averagef250
averagef250 is offline
You can make 425+ horse from any set of fe heads out there with exception of FT stuff. C7AE-A's are probably pretty close to all the other early big port heads. They'll make big power, just might not be as efficient at doing it as the later smaller port heads with a good port job.
Old 11-19-2004, 12:35 PM
Paul Garvin's Avatar
Paul Garvin
Paul Garvin is offline
C7AE's are small port "velocity" heads. They are almost identical to the later C8AE and D2TE heads. The ports are much smaller in diameter than the C1's C3's C4's and C5's. C6 was the transition year for FE heads.
C7's can be made to run with some mild port and polish and CJ valves. I ran a set for years in my 73 250 4x4. They are good heads for a 400-450hp FE. If you want more than that you really should look at the big port heads or aftermarket.
Paul G.
Old 11-19-2004, 08:27 PM
76greenmachine
Thanks Paul For Replying! I Havent Been Able To Find A Web Site With Any Info. It Helps To Know If Someone Else Knows What Im Asking. I Was Wondering If Thier Is Anything Special About The Heads Or If Other 390's Had Them And Also What Other Engines Had Them? Thanks Again For The Feed Back!
Old 11-19-2008, 05:18 PM
art015's Avatar
art015
art015 is offline
5 year old post but here ya go;
67 390 heads
Same casting as a 390GT head. Only difference between a std. head and GT heads were the exhaust bolt pattern. GT heads had 14 bolts where a regular 390 had 8 bolts.
Same heads that came on a 67 GT500 Shelby.
Standard stuff, nothing special
Old 11-19-2008, 06:43 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
Paul G.
How do you have a diameter on an rectangle shaped ports? Diameter work with round or oval ports.
Old 11-19-2008, 08:42 PM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
Bear... Paul G hasn't posted since June 05. So...he might not answer ya? This thread is from 04. But better late than never as they say?
Old 11-19-2008, 09:45 PM
Redmanbob's Avatar
Redmanbob
Redmanbob is offline
I still have to agree that after much reading a 425 hp FE isnt a difficult task with any of the heads if the rest of the engine is complimentary. AND DAMN!! I cant wait to see how the C4's breath!
Old 09-13-2012, 11:57 PM
Andrini's Avatar
Andrini
Andrini is offline
I have a set of c7ae-a with 16 bolt exhaust are they just stockers or are they gt?
Old 09-14-2012, 09:52 AM
art015's Avatar
art015
art015 is offline
67 Mustang/Cougar/Torino/Comet 390
No performance advantage over std. 390 heads.
Old 09-15-2012, 04:56 AM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
Also 67 Shelby GT500 used the C7AE-A heads.
Old 09-15-2012, 05:50 AM
RapidRuss's Avatar
RapidRuss
RapidRuss is offline
FE "Freakin Expensive"
Thats one thing I have never run across out of my years of playing with FE's ..the C5 head ...
Hmmmmmmm....
Old 09-15-2012, 04:07 PM
Andrini's Avatar
Andrini
Andrini is offline
Right on thanks rapid Russ, do you know how to distinguish Shelby gt heads from std ones?
Quick Reply: Anybody Have C7ae-a Heads? Good Or Bad? 390 Or 428?
