400 Cylinder Head Casting Numbers - Ford Truck Enthusiasts Forums
Old 11-17-2004, 05:35 PM
Mud Rat's Avatar
Mud Rat Mud Rat is offline
Mud Rat is starting off with a positive reputation.
Question 400 Cylinder Head Casting Numbers
I have two heads for the 400.
One casting number is D5AE-A2A, the other is D5AE-A3A.
Are there differences between the two?
Old 11-17-2004, 05:52 PM
74 F100 351m's Avatar
74 F100 351m 74 F100 351m is offline
74 F100 351m is starting off with a positive reputation.
:-x25 ??????????????? :-x25
Old 11-17-2004, 07:46 PM
BrentKasson BrentKasson is offline
BrentKasson is starting off with a positive reputation.
My guess would be different years maybe, or perhaps casting places. I think i saw that all cylinder heads on the 400 were the same from 75 on? Check out bubbaf250's website. Good info there.
Old 11-18-2004, 07:44 AM
Donnie Knight Donnie Knight is offline
Donnie Knight is starting off with a positive reputation.
I think this link may supply you with some info, http://home.earthlink.net/~bubbaf250/parts/pics03.html
Old 11-18-2004, 02:43 PM
squirrelhunter squirrelhunter is offline
squirrelhunter is starting off with a positive reputation.
Smile
Both heads are 74.5 cc. They are 77-later 351M/400
Old 11-18-2004, 03:26 PM
beartracks's Avatar
beartracks beartracks is offline
beartracks is gaining momentum as a positive member of FTE.
The first two digits indicate decade and year. In this case 1975. I believe the factory tolerance for 2V heads was 78 to 80cc.
Old 11-19-2004, 07:54 AM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
The A2A & A3A are engineering revison #s. I don't know of any place to find out exactly what was changed but I'd suspect they're virtually identical. I wouldn't hesitate to use them on the same motor.
Old 11-19-2004, 12:19 PM
beartracks's Avatar
Compare the exhaust passages and the area around the exhaust valve seat. Look for the air injection boss "bump" and a restricted exhuast port.
Old 11-21-2004, 11:22 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Yes there were two different heads for the 400...
They are the same as far as chambers and valves go...
The difference is that one has a rotator thingy on the exhaust stem, the other one doesn't.
Which Heads and Block? srsbjohnson FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 08-06-2013 04:28 PM
400M Casting Codes and Date Stamps fyreduck1921 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-02-2013 01:41 PM
D3AE-A2A-88cc Heads? fordlowboy 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-31-2002 10:28 PM
400 Heads??? skud 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 01-26-2001 06:22 PM
FE Head Identification tmod 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-21-2000 10:44 AM
Tags
351m, 351m400, 400, a2a, casting, cylinder, d5ae, d5aea2a, ford, head, heads, id, identification, number, numbers, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
